ramairthree
- Joined
- Nov 30, 2010
- Messages
- 101
I have had these set up in a 2 car garage for a while.
These are the small RTA wall cabinets.
My cabinets have the small, single U brackets, and one place to attach the brackets to the cabinet. They hand from the upper track on this.
I have some cabinets that are new I am going to mount.
They came with the larger, double bracket. This bracket pushes the top of the cabinet farther from the wall, so that it is not level.
There is no attachment point lower on the cabinet to put on a lower hanging bracket.
Whenever I try to order the original type brackets I have, I can only find the other, larger bracket which does not work right.
Does anyone know where I can get the original type brackets.
These other brackets are the ones that you put on the bottom and top of smaller cabinets, and bottom, top, middle of larger cabinets,
but obviously don't work on the cabinets with only a top mounting spot.
Thank you for any info.
