ssffnomad
When installing Glass in a Blasting Cabinet, using new rubber gasket with a locking bead ? What’s the best procedure ?
Thank you, Dave
Thank you, Dave
Dave,
These items will help: silicone spray lubricant, nylon windshield stick and lock strip lacing tool
1. install the gasket in the cabinet opening and spray liberally with silicone lubricant
2. Starting at one corner carefully install glass in gasket with nylon stick
3. Spray lock strip with silicone and insert in groove with lock strip tool. Try not to stretch lock strip. If possible, install ends of lock strip first and force excess into groove without cutting.
Good Luck,
Doug
