Glue master?
dogdad
Down south
Question for all the glue masters... This cheap sears magnet tray has fallen apart as you can see...and I know they are cheap as mud, but what glue would you use to maybe give it a permanent fix? Thanks ......ps...sears would not replace it.
Agentwho
Baltimore
I would think any epoxy rated for metals should do the trick. Just scuff up the surfaces mix the glue and slap it on.
Matt M PA
SE PA
..and Sears won't replace it? I guess it's not a hand tool.
I don't know if you have any...but I've found 3M emblem tape to be very strong. You know, the double faced taped used to hold car emblems on. I've used this tape on all kinds of things.
RTV is actually a good glue for something like that as the pan is fairly flexible, and the rubber qualities of the RTV will absorb any differences in thermal expansion.
You can see the epoxy they used failed...
harvey29
Kansas
I used gorilla glue on a entertainment center door with no other fasteners and its holding up fine.
xj31
Exactly. Works great on those trays
D
dogdad
Down south
Can you be more specific... I google RTV glue and see lots and lots of different choices,, mostly gasket seal. Thanks
NUTTSGT
Northern Central Ohio
I myself would probably try some Clear RTV. If it doesn't work, it'll peel off easily.
Any of the Gasket sealant RTV's will work fine, so will ordinary bathroom RTV. From a practical perspective, there are really only three basic types:
Std (smelly)
low VOC (expensive, use in aerospace apps a lot)
and High temp for exhaust and other high temp uses.
I think the RTV II for exterior construction use may be somewhat different as it's made to not sun-rot.
After that it's all about dyes and marketing.
I've actually used bathroom RTV on engine gaskets with no issues. (white looks a bit odd if it shows, but it worked exactly the same as Permatex RTV for ordinary gasket use...)
D
dogdad
Down south
Thanks again for all the input.....I know I can just go buy a new one for very little.....but it'll probably end up coming apart eventually,, and didn't care for Sears in not replacing it...jmo
turdferguson13
Exact same thing happened to me. I heard they wouldn't cover it under warranty, not that I would want another just to do the exact same thing.
I cleaned the glue completely off of both surfaces, scuffed the metal up, and applied a two part epoxy (my shop uses Wurth FixAll). I haven't had any issues since then.
cyato
Orange County, CA
I highly recommend Goop adhesive.
http://www.homedepot.com/p/Amazing-...ontact-Adhesive-and-Sealant-130011/100372166#
Despite the goofy name, it really is "amazing" for bonding smooth surfaced parts. I believe it is silicone based, but unlike silicone sealants and caulking, it is an adhesive. A bead of goop on each of your magnets, a little weight and leave it overnight and you're set. They will never come off on their own, but you could pry them off with a putty knife if you needed to. All of my co-workers were skeptical when I first suggested it, but everyone became a convert after experiencing how well it works. Unlike most epoxies, the extra bit the squeezes out, can be easily cleaned off without damage to most delicate parts. The only drawback to Goop is that it takes a while (overnight or longer) for it to cure when used generously since it is not catalyzed.
Another alternative would be Devcon Plastic Welder.
http://www.amazon.com/dp/B003NUGL9S/?tag=atomicindus08-20
Despite the "Plastic Welder" name, this structural epoxy is fast, smelly and bonds almost anything with amazing strength. Not as easy to find as Goop, but great to have around and much stronger than your typical "5 minute epoxy".
whyNick?
Midwest
Shoe Goo!
I recently rediscovered this stuff and have been using it on everything. It works good.
