Gluing closed cell foam
JackOfDiamonds
Idaho (USA)
I have a cloth lunchbox and I want to take sheets of closed cell foam to make custom compartments inside.
Is there a type of glue that works well?
bradleydavidgood
I would not put glue with your food just keep it loose in there and it's not going to stick well anyway with the condensation
J
JackOfDiamonds
Idaho (USA)
It's not going to be used for food. I'm going to store expensive optics in it.
I never transport expensive things in a bag that looks like a bag of expensive things. Always use a lunchbox, tackle box or diaper bag.
Firstram
If you’re talking about blue foam sheets, West Systems epoxy is my go to. You can also lay it out in slices/layers and wrap the outside of the stack with duct tape.
Some dimensions and info about the product would help.
Sounds like you have down this before !
I would be concerned that the heat from the epoxy curing would cause the foam to melt.
Firstram
Don’t mix it that hot! Don’t forget to peel the plastic off of the foam before gluing it.
AEAdam
SE PA
Yeah, I’d think a polyurethane is what I’d use. Epoxy is too rigid and may crack. There are several different polyurethane glues on the market. Most but not all foam up. Gorilla glue would work, but so would low expanding foam insulation. I think gorilla glue is the right answer for this application. Be sure to make a sample and test it.
Beerhippie
Far NE Oregon
For flexible foam--like Armaflex or neoprene--I use contact cement. I apply a LOT of this stuff around the brewery and it holds well and long.
Armaflex sells a special adhesive for their closed-cell foam insulation. I bought some. It's contact cement.
I use DAP Weldwood brand contact cement from the hardware store.
y'sguy
Tulsa, Oklahoma
You can also check into 3m style soft and thick dimension double stick tape. You can also support it further with straight pins, just like a nail.
olsenmotorsports
Chicago, IL
We use Landau Top adhesive on foam in our space. Works great. Little smelly but it will last for years.
We use it on the roofs of cars for foam as well as sound deadening. That is one of the hottest areas of the car and sticks amazing as long as it is applied as instructed.
Hope this helps.
seber
Deep East Tx.
Hope this helps.
That's just contact cement in a spray can.
olsenmotorsports
Chicago, IL
Kind of. But not really. It’s specific to upholstery style which is perfect for OP’s application.
We used to use the spray can contact cement. The upholstery grade stuff in our testing has been far superior.
Firebrick43
West central Indiana
Epoxy curing will not cause the foam to melt. It works very well for XPS foam and would be my choice.
Lots of people(and I) cut and shape xps foam and then use epoxy to not only glue but slather it all over and fiberglass it without issues
In fact I would suggest to use a layer of two of 2oz fiber glass to fiberglass the outside, it will strengthen it immensely.
It will not cause an issue with the glue joints being to brittle. The glue or it’s bond will not fail if you lightly sand the xps, the XPs itself will break aside of the joint.
no704
Or just get a block of tear out foam like found in a pelican case.
