Guys, will this kit cover most of the newer cars/trucks? Or is there a better kit you would suggest?
Thanks
http://www.amazon.com/dp/B007WQQHA2/?tag=atomicindus08-20
Thanks
I bought this kit a few months ago and really like it. A little expensive but it's a very complete kit. I don't do this for a living but do enough that I wanted a dedicated terminal release kit instead of using paper clips and stuff. I had a wire harness to replace some bad wires in and used it as an excuse to buy this kit, it was my "payment" for that job.
http://www.amazon.com/dp/B00EDEEICA/?tag=atomicindus08-20
I am not the only one who would read every word with interest.I have picked up the two snap-on sets one is obsolete
If you are really interested I will do a write up in detail with links but it is out there stuff, like 64 pin circular connectors using 28 gauge wire. pins are little under $2 each and you use a $600 crimper.
The blue point is a steelman made set.
http://www.foxruntools.com/19-piece-master-terminal-tool-kit-part-js95978.aspx
or you opt for the official GM kit:
https://gmtoolsandequipment.com/en-US/Pages/ItemDetail.aspx?itemID=103685
Steelman makes several kits. I've had good luck with them.
Wow! The GM kit is a little costly!![]()
Agreed!
If you do get some time, please do, pi_guy![]()
Yes
Works as a lubricant does not leave residue, and does not dissolve or effect plastic or rubber componets.
It has low viscosity enough to help in disassembly of connectors were dielectric grease only really works with assembly.
I have them all and I keep several duplicates.
Some times one breaks other times you hit the spot well with one tool vs the other.
Typical Garage Journal answer, buy it all. Is there on kit you typically reach for first?
Bob
So, how do you strip that wire without nicking it? Is the rest of your posting somewhere else where I can read?
Bring up an old thread, I have been looking for recommendations for a terminal release tool kit. Its for occasional use on mainly GM vehicles but I do work on occasions other makes and models.
I have read many good reviews for some of the Steelman tool kits but when I look online I see many kits labeled "Euro" or "VW/Audi" and I was not sure if they would work as well on GM cars.
Bob
Thanks
Thanks
the only thing I did not mention is I use a digital microscope to confirm seat with pin in housing.
When it gets warm again I will take some pictures of my collection of wire tools.
Other minor tip having extra and different pins can often be used to make connectors for testing. There is modeling plastic that dries hard with air, I find pins that will fit a connector and wire them. Then I squeeze the plastic about the pins to make a mating connector. Let dry and now I have a test setup.
