gonne need floor help...
XsteveedgeX
northern ohio
let me start by saying, i will get pics! that said, here's the plan: epoxy floor. the problem: a few cracks, some heavy duty looking oil stains. the fix (i hope): grind out cracks and fill with self leveling concrete, muric acid the hell out of it, power wash the bajeezes out of it. anyways, and tips, suggestions, comments? is the epoxy gonna work over the patches in the floor? let me have it...
LegacyIndustrial
deerfield, IL
Make sure you use an epoxy patch for the ground areas. Once cured, grind them flush and you can apply any (2) part epoxy over-top.
Choose a patch that is similar in color with your coating, if you can.
Also...
once you grind those really oily patches, wait a day or two, if the oil is gone you are good, if not treat with acetone and kitty litter until it stops bleeding.
