Good compressor for my home garage?
SMB47
Needing an air compressor. I'd like a decent one, but don't want to take out a second mortgage.
Looking for suggestions that aren't complete Chinese imports like most I have been seeing.
I'm thinking around a 5HP.
Davefr
OR
Believe it or not, but the HF 5 HP/60 gallon unit is made in the US by Bel Aire and features an Italian pump and Mexican motor. (not much Chinese).
It has consistently good reviews.
bsaint
Manchester, CT
How much air do you realistically consume? Im rebuilding my main 5 hp air compressor right now but Ive been doing OK with automotive repairs with my home 3/4 hp emglo (Jenny) air compressor like this one.
http://www.zoro.com/jenny-air-compr...m_source=Bing&utm_medium=cpc&utm_campaign=PLA
I couldn't break out the constant air usage tools (i.e. air drill or air grinder) but for an impact it does OK.
You might be fine with a quality build 1.5 hp 30 gallon single stage compressor.
CompressorPros.com
SC
I guess it depends on what you are actually doing. You can find a 5HP that makes 14-15 CFM or one that makes 17-18 CFM.
If you are using mostly impacts, you may even get by with a single stage. If you are sanding or painting, you probably want to step up. Be glad to work with you on pricing on any of these below. We sell several brands, but BelAire has a good selection for what you may be looking for. Went small to larger for the links. Let me know if you have any questions and good luck in your search
http://www.compressorpros.com/air-compressor/portable/26-gallon/single-stage/belaire-5026vp/
http://www.compressorpros.com/air-compressor/60-gallon/single-stage/belaire-2061v/
http://www.compressorpros.com/air-compressor/two-stage/60-gallon/belaire-216v/
http://www.compressorpros.com/air-compressor/two-stage/80-gallon/cast-iron/iron-series/belaire-418v/
Tsquare
San Diego
http://www.compressorpros.com/air-compressor/60-gallon/single- stage/belaire-2061v/
Do not mean to hijack, but what compressor would you recommend for a home garage using a sand blast cabinet (quieter would be a plus)?
CompressorPros.com
SC
That's a little tough since it will really depend on the size of the nozzle opening. At the very least, you might take a look at the 418V. It is a slow turning cast iron pump and puts out 18 CFM. If you want something that is a good bit bigger and really quiet (I got to hear it run and was amazed at the lack of noise) check out the RCP-7581VSC2. It has a 10HP pump turning at 600 RPM, so it just chugs along, but it makes 27CFM.
Here are the links and just e-mail me if you have any specific questions or if you want a better price (who doesn't?) We are limited at times on what price we can advertise. We have more flexibility on some, so don't hesitate to ask. [email protected]
http://www.compressorpros.com/cp/ai...on/cast-iron/chicago-pneumatic-rcp-c7581vsc2/
SMB47
Those are some nice compressors to look at. I just need to figure out if I want portable or not
Not enough info !
If you have no plans to run a sander, die grinder, sand blaster then you do NOT need 5HP !
If you are only going to be running a 1/2" impact, air ratchet, air chisel or nail gun a 2-3HP compressor is adequate. There are a few GOOD 1-2HP portable (no wheels) compressors out there from DeWalt, Makita and California Air Tools.
MrGiggles
Any portable compressor that has decent output is going to be gas powered. The electric ones are primarily for running nail guns and other low consumption tools.
With the time spent installing it, it's worth it to go big from the get go. It's really nice not having to wait on air, and the capability of running a die grinder or media blaster is worth it.
Set aside 1000 bucks, then get the HF unit and necessary install accessories.
