Good Large/budget Drill Press
TTMotorsports
Lucerne Valley, CA
I have since sold my nice Tree Vertical mill due to space and needing a forklift to move it along with the rotary phase converter since no 3 phase power at my old house/shop. I am used to using that to mainly drill holes because I could slow it down to the right speed and apply more pressure than necessary to drill out the holes. I am looking for a drill press now that I can slow down enough to drill 3/4" holes in steel efficiantly. Most drill presses I find the slowest speed is still too fast for 1/2" drill bits. So looking for a new drill press that I can drill holes with more easily and at correct speeds for drill bits larger than 1/2"
I have been looking on craigslist and found a few but the sells don't know the speeds so I don't know if they are any good.
rsanter
visalia ca
I have a delta with a 3ph motor (but has a VFD) so can run on 1ph and be speed adjustable.
It also has the variable speed reeves drive
matt_i
The drill you want is probably an Avey, Edlund, Fosdick, Alzmetall or Buffalo that you don't find on every street corner. But they aren't things you wrangle into the bed of a pickup truck either. Something about needing more structure to drill that large without chatter.
Even a "nice" 20inch drill press like a Clausing can only go down to 300 rpms and that's too fast in my book for drilling 3/4" holes. I have a VFD on my DP but it lacks power and the motor cooling is suspect below around 30Hz, but I would choose the mill 100 times out of 100 for a 3/4" hole.
The back-gear of a knee mill is perfect for this application, you already know that, you can move those with a pallet jack and a drop trailer if you play your cards right. I moved mine with a 3 ton engine hoist before getting forklifts along the way.
dr_clyde
Holland, MI
You want a gear head press. I have a Solberga that is rated to 1” twist drills? in steel. I absolutely love it.
8 speeds, I believe the slowest is 150 rpm. Reversible spindle for power tapping.
Davefr
OR
Agree, just set the pulleys at the lowest speed setting and dial down the VFD and you can get down to two digit RPM. If the motor is decent size you'll also have plenty of torque.
bob15
Northeasten, CT
Not sure how many holes are needed or the size of the material you are drilling, but how about using a mag drill? You could even mount/bolt a steel plate down for the drill and use it as a drill press.
tarbellb
Oregon
T
TTMotorsports
Lucerne Valley, CA
Also what do you think this Parker Precision Drill Press is worth???
TailGunner3000
New Jersey
The Parker is a pretty standard asian import. They make those badged to many different companies. I have two - one Ridgid, one Jet. The are decent wood drilling machines, but average on metal. I don't know your market, but I paid less than $25.00 each, albeit at auctions.
If you come across a Walker-Turner, I'd highly recommend you buy it if the price is right. It's my go to drill press. Superior even to my Delta and Atlas.
Davefr
OR
About $150 IMHO. Those early Taiwan machines were decent. Table lift, wide speed range, TEFC motors, decent quality, etc. The came in a gazillion different brand names.
lilredex
Toronto
I have one of those early eighties Packard look-a-likes. It is dressed up as a HF #38142. I got mine for $40, but it needed a motor. Recommended highly!
lis2323
Gear head unit as mentioned is a good option.
and a good set of twist drills...
and (or) a 3/4” Weldon shank adapter and annular cutters.
  • Like
Reactions: Job
T
TTMotorsports
Lucerne Valley, CA
Yeah they want $375. Not going to spend that much
Also I saw mag drill were fixed rpm and with most twist drills 650 rpm is too high and I don't want to spend a bunch on annular cutters either.
T
TTMotorsports
Lucerne Valley, CA
Gear head sounds good to me but I haven't seen any used ones for sale and new are pricey. Would rather buy a used mill for the $2k they cost nee
jh87
Indiana
I have the harbor freight 20” production drill press. It goes down to 180 rpm. It also has a large t-slot table which is great for me because I do a lot of repeat work in jigs. I’ve used up to a 1” twist drill in it without issue. Mostly I do 1/2” holes. I’ve also used larger hole saws. This is all in steel btw. The only issue I’ve had is that you really need to crank down the nut on the spindle pulley as it only relies on a taper to hold it together.
T
TTMotorsports
Lucerne Valley, CA
I found one of these used and will bring some steel and a couple bits to test it out.
jmarkwolf
Southeast Michigan
I found this Wilton 20in drill press, on Craigslist, 5 minutes from my house, for $100, including a vise. The only issue was the belt tensioning device had become disengaged. Easy fix.
There were no drill hits in the table nor the vise. I'm still tickled to have found such a deal.
Jet sells this model now for $1500.
I've since cleaned up the column and replaced a belt. Works great.
lis2323
I think you need to borrow or rent a mag drill to use for a day. This will be a good cheap way to understand operation and the limitations this tool will provide for you.
From the conversation you need to stick to looking for a good drill press.
