good stain or paint or ? for 2x6 trailer decking?
rockwind1
las vegas
I assume a lot of folks have a typical trailer to haul their tractor around. mine is a pretty nice 15k lb rated 20ft trailer, 20 ft 2x6's run the length of it. just typical pine, untreated. it's been looking a little dry and weathered and thought i would put something on it,,
anyone found the perfect stain to resist strong arizona sunlight? and the occassional monsoon?
i was thinking boiled linseed oil,, also used motor oil? or maybe just olympic deck stain.
R
rockwind1
las vegas
Are you sure it’s not PT?
That seems rather odd that it wouldn’t be-
like 99% positive,, i've used pt for bottom plates on houses so i know what it looks like. here is pic of trailer
Garcky
Twin Cities Metro Area, Minnesota
Not an easy decision. I'd probably use linseed oil, thinned with some mineral spirits. Multiple coats. Takes time to dry. Won't last forever, but you can always sand the deck and reapply. That's the classic finish, and still works darned well.
I'd skip the used motor oil. It will always remain oily and will stain clothing and just sit there. Not a good finish for anything really. It doesn't dry.
Firebrick43
West central Indiana
Boiled linseed oil is what you should use.
Growing up we used used motor oil on two lowboys, a flat deck trailer, and half a dozen hay wagons. It does make a mess, we sprayed it on with a cheap garden sprayer. We normally applied in the fall as none were used much during the winter. It could be slightly slick for wheeled vehicles while loading on the low boy trailers but not to bad and not to foot traffic, again next spring. Never had it stain clothing and while I guess it technically does not dry it is absorbed by the wood, washed away by water, oxidized, and eaten by bacteria. It was not noticeable for the most part by the end of the next summer.
K'ledgeBldr
Johns Creek, GA
Well, a pic of the topside isn’t going to do much- it’s weathered. What about the underside? Are there any mill stamps? That will tell you for sure.
I’ve seen a lot of utility trailers over the yrs- 35+yrs of construction- and there is a local trailer builder here in the metro area- they all had PT decks. It’s just the most logical material to use for a utility trailer that is constantly subjected to weather.
u2slow
BC
Oil or wood preservative for me.
Paint gets beat up quick and becomes high maintenance.
R
rockwind1
las vegas
Here is underside. Haven’t seen any stamps
K'ledgeBldr
Johns Creek, GA
That seems strange-
Anyway, I spec’d (and personally use) TWP for decks. It will work just as well on that trailer. TWP is an oil-based penetrating stain/sealer. If you re-coat every 2-3yrs, it should last 20yrs. There is a clear version; and has UV inhibitors- unlike BLO, Thompson’s, or other type sealers.
Used motor oil will certainly do a similar job- but I think there are “better” ways to use used motor oil.
Stelzer
Portland, OR
It is the tint in a deck stain which acts as the sacrificial barrier; something a homebrew of BLO would lack. I'd use a penetrating oil semi-trans, and plan to recoat it every 2-3 years. Stay away from film forming finishes such as acrylics or even solid stains, as they are much more prone to peeling, flaking & chipping. The only product I get from big box stores, (besides when I need BIN Shellac), is Ready Seal, and it's available in most Home Depot & Lowes stores. I do 40-70 decks & fences a year, and I switched to Ready Seal several years ago after Sikkens changed to ProLuxe back in 2015. Armstrong Clark, TWP & Bakers also would work well, and all can be easily recoated in the future.
solo machinist
North West, Ohio
I use this on all my trailers twice a year for touch up. I've used this for 4-5 years with no issues.
We also stained our split rail fence with this.
Jeffncs
I used white oak treated with ATF. I hit all 4 sides with a couple heavy coats before installing the boards. Now I recoat the top semi-annually. 5 years later and the wood looks awesome.
Stevewr54
Cabot's Australian Timber Oil. My trailer decking looks as good as my patio deck. Steve
