djkyle65
Anyone know of a good tap and die set?
Do you have any other recommendations? Irwin's quality seems to be fluctuating too much these days, and it won't be long until they start cheapening the Hanson tap & die line as well.
I have an older Mac set that is a rebadged Vermont American set. I still see them for sale just the case is different. Never let me down
most mac sets i have seen are ace/hanson.........http://downforeveryoneorjustme.com/http://www.unionbutterfield.com/I can't get the Union Butterfield link to work for some damn reason.
Keep in mind that tap and die sets are pretty much inherently junk if you expect to create threads with them. Decent threads on most fasteners are rolled not cut. The only good purpose I can think of for tap and die sets is cleaning the threads on existing bolts (removing old loctite or anti-seize), chasing threads in holes that already have them, and installing helicoils in aluminum. Since they're pretty much a cleaning tool, there's no reason to aggravate over the quality of them unless you've got a set that was hand-made by a guy with a file in Nigeria or somewhere.
If you use the proper drill bit size, creating threads is very easy and effective. It just takes a little time and technique.Umm... okay... sure.Keep in mind that tap and die sets are pretty much inherently junk if you expect to create threads with them. Decent threads on most fasteners are rolled not cut. The only good purpose I can think of for tap and die sets is cleaning the threads on existing bolts (removing old loctite or anti-seize), chasing threads in holes that already have them, and installing helicoils in aluminum. Since they're pretty much a cleaning tool, there's no reason to aggravate over the quality of them unless you've got a set that was hand-made by a guy with a file in Nigeria or somewhere.
Don't worry, you're not the only one confused about that guy's statements - it doesn't any make sense to me either.What are you talking about.If you use the proper drill bit size, creating threads is very easy and effective. It just takes a little time and technique.
I actually do have this set and it works OK for light duty stuff, but not for any high grade steel cutting. The wrenches are complete **** though, but didn't expect much when I bought them years ago.
what is the difference between a tap and thread restorer tool?.............![]()
i have used taps for years at work and home to chase threads and never had a problem............what is the diff between a tap and thread restorere tool?.............![]()
kartracer55;364609 This is a thread "restorer" kit... [url said:http://www.sears.com/shc/s/p_10153_12605_00942275000P?vName=Tools[/url]
Snap On sells one that is strikingly similar, and I must say, this set is an absolute life saver and I highly recommend getting one.
