Goodman heat pump air handler
Waltjr1
Will a new 14.3 SEER Goodman air handler work with a 17.2 SEER Goodman heat pump?
karoc
Hemphill Tx
Yes, your condenser has the capability to be 17seer if match. But both are so close that it really doesn’t matter.
fitter30
Peace Valley,mo
If coil is using a orifice for expansion device might have to be replaced with a different size. A distributor with their tech can give you the correct size. Expansion valve should be ok.
