lowe.joshua51
I have a ng furnace/ac packaged unit and I went to use the AC for the first time since last summer and the blower fan came on but the ac compressor and the evaporator fan didn't come on. Obviously no cooling.
I did some testing of my thermostat wiring and all was good. I was getting 24VAC on the yellow wire from the thermostat.
I thought it might be the capacitor for the compressor/evap fan (it's the same capacitor for both) but that checked out.
I manually pushed in the contactor and everything came on and worked fine but I would have to sit there till it's cool enough inside.
Upon further investigation the contactor isn't getting 24VAC which is why it isn't engaging. The 24VAC line that leads to the contactor passes through the High Pressure Switch but there isn't 24VAC on either side of the high pressure switch.
I attached two pictures of the wiring diagram. The terminal I'm looking at is #12 that goes to the HPS then to the contactor. Does anyone know where the power for #12 comes from? There is no power on that connection.
I'm not experienced in these things but I'm decent at problem solving and figuring things out. This has me stumped though.
Thanks for any help you can give me!
