muskaman67
- Joined
- Jun 6, 2008
- Messages
- 290
Hey guys, just picked up a new tool to go along with my Dewalt 18v Impact.
I haven't really wrung mine out enough yet to know. Recharge time is pretty short though.How is the battery life on those?
Do yourself a favor and hide the 3/8 adapter, you likely won't need it much. (except for certain special sockets or bit adapters) It's effective power is well within the range of typical 1/4" sockets.
Even better to use the sockets with the built in hex shaft any time you can. They get a little more power that way.
very true. ill most likely be putting my 1/4 adapter on it instead.
If you don't plan on buying more Milwaukee m12 tools the Bosch ps41 model is more powerful. I kept the milwaukee only because I they have a more extensive line of tools.
I would say no the 3/8 milwaukee impact is not more powerful than the Bosch. And you sure got a lot of batteries.
Waiting for this sucker
The Bosch PS41 has 930 in.lbs of torque
http://www.boschtools.com/Products/Tools/Pages/BoschProductDetail.aspx?pid=PS41-2A
The Milwaukee 2451 3/8" impact has 1,000 in.lbs., I realize that this may no be a lot more, but how have you determined the Bosch has more than the Milwaukee? My brother has the PS41 and IMO its weaker, but that is also using a 1/4"hex to 3/8" adapter too.
http://www.milwaukeetool.com/tools/cordless-tools/m12-cordless-system/m12-cordless-lithium-ion-3-8-inch-square-drive-impact-wrench-w-ring/2451-22
As to batteries, I like to be able to use them all if needed, on a few projects I've had all of them and even a few of my Makita impacts running when we were throwing up or taking down Santa's castle, the gingerbread house (12' x 12' x 14' high), so multiple guys working, multiple batteries make it possible.
TheGrooveking
By torquing in lug nuts incrementally and see what is the limit of the guns ability to remove them. The Bosch is more powerful (yes I am using an adapter with it also). If you are going by the number that the Milwaukee gives you, then the Milwaukee M18 high torque impact would be the most powerful torque gun by far at 450 ft lbs. In reality it is generally accepted that is not as powerful as Snap On's meager 400 ft lbs of torque.
