Got it done.
logical
Northern fringe of the Motor City Suburbs
Looks good. What are the details...products used? I'm guessing grind, tinted/pigmented poly of some sort, flakes, scrape and polyaspartic clear?
No problem if you don't want to say, but I am about to have mine done and curious what rate they charge in your area.
cody1325
Southwest Virginia
Love it!
The basement floor has long needed a lot of attention, and I'm leaning more into garage floor coatings instead of paint as it has been for 50+ years.
steve308
Company that did the job is 'Floor Tech'. Product used is 'Penntec'. Floor was tested for moisture and hardness, diamond grinding, base coat applied. Lunch. Epoxy and flakes (I chose domino) flakes scraped. Walk on after 24 hours, ok to drive after 48 hours. Garage is just under 500 square ft and I paid to have the coating applied up the side cinder block. Final cost with 'home improvement show' discount was $4600.00 I couldn't be happier with the results.
