Got me an anvil
jaker10
Bartonvillle Illinois
I picked this up today, I hope I did OK. $150.00 I've tried to look up about anvils and there marking and I can't find much. The old boy had 4 and I picked this one because of the logo and it was in the best shape. He had one that he said was 250lbs. that was in very bad shape and it had a hole in one end and he said it was a mouse hole brand ? One unmarked and one marked Swedinson (?) cast iron made in Sweden. If it is any good I may go back and buy it also. Here are pictures of the one I bought. Can anyone tell me the brand with the arm and hammer? And with the 15 marking is it 150 lbs. Also any idea when this would have been made. Thanks much.
RatchetMan
I think that the brand on that one is Vulcan and anvil snobs would consider that one a so-so quality brand. If the Swedish anvil is in good shape you might jump on that one as Swedish anvils are often prized by collectors.
RatchetMan
If all you did was buy it so you could beat on it then it will serve its purpose. No reason to worry about selling it.
J
jaker10
Your right. And it will get beat on, but I was hoping to get one of those anvils that only come along once. He had one that really had a nice tone (and was told to buy it) but it was unmarked and like a dumb *** I went for the logo. The one made in Sweden is marked cast steel so I went with:dunno: this one.
Zrexxer
Pflugerville, TX
No, no no, see, in your first post you said the Swedish anvil was cast iron. If it's actually cast steel, then yeah that's one of the ones to get. There is a significant difference in a cast steel and a cast iron anvil.
J
jaker10
YOU are so Right. Now I'm wondering my self. The one made in Sweden did have A thud and not a ring when striking tho. I think (will look again) it said cast steel. It is also already mounted on a stump of wood. Would that take away from the ring. I'll give the old boy a call Wednesday and go take another look.
wild cowboy
Birmingham
drop a 1" steel ball bearing on them from 10" or so high, note the percent of that height that the bearing bounces back up, this will tell you a lot about what it is worth, along with the weight and condition. 80% or higher bounce back = big bucks
below 50% and it's more of a door stop
you can get some big USA-made ball bearings here:
www.ebay.com/itm/290839303554
also, keep in mind that value rises exponentially with weight, so a 275lb anvil may be worth 4 or more times what a 150 lb one is
RogueFab
Oregon
Sounds like an ok or good price in my neck of the woods. Anvils around 150 lbs seem to get listed for 200+. I don't want to pay that though... not going to use it enough.
bluebolt
Benton LA
Yeah that's a Vulcan #15. See here for more info http://www.anvilfire.com/anvils/donated_007.php
Vulcan anvils pretty much go by the model number for weight, a 12 is 120 pounds, your 15 should be 150 give or take a little.
The only "sold" #15 Vulcan I found on Ebay recently was about $275 plus.
I think you got a good deal.
Now go back and buy more anvils!
organ
Atlanta
If an anvil has raised emblem/lettering/numbering... it's obviously cast. Wrought anvils will have inset emblem/lettering/numbering.
Black Frog
I use/buy/sell a lot of anvils. Mouse Hole was the brand of M.H. Armitage. They are a well-known, but older looking forged anvil. Many refer to them as the Old English style, usually with pointed tops to the feet.
There are several Swedish makes of anvils, usually all cast steel of very good quality. Soderfors, Paragon, Sisco, Kohlswa are some common names you'll see for Swedish anvils.
The one you pictured with the arm and hammer logo is a Vulcan made by the Illinois Iron & Bolt Co. Older ones don't have the logo on the side, but you'll see a raised "I I & B Co" under the horn. They are cast iron body with a steel face plate, but the steel plate is rather thin which is why it isn't considered a top quality anvil. Fisher anvils are also cast iron but have a much thicker steel face plate.
Many people confuse cast Vulcan anvils with the arm and hammer logo with the actual Arm & Hammer brand anvil made by Columbus Anvil & Forging Co which are top notch anvils. Forged wrought body and steel face. When you see the stamped Arm & Hammer logo on the side, that is an actual A&H anvil (not a Vulcan). If it is a raised cast logo, it is a Vulcan.
Here's a couple A&H anvils stamped logos so you can see the difference vs the raised Vulcan logo in the original post.
J
jaker10
Well I went and bought another anvil today. Its weight is 150 lbs. (on my deer scale) I can find no markings on this one but a serial number. A5494 Can anyone ID this. Here are pictures. It does have a ring when tapping with a hammer. The other one he had was a 90 lbs. Made in Sweden and was marked Cast Steel.
J
jaker10
I found what looks like what is left of a diamond shaped marking. Any idea what brand from that?
J
jaker10
If what I found on the internet is right. Trenton by the diamond and 1899 by the date code (A5494) And the hour glass pattern on the bottom. Sound right?? Thanks for any info.
Canoe50
Rochester, NY
Go back & grab that cast steel one if it's in good shape....high quality.
