MrMark
I see you were CHP. Motor officer? CHP has always seemed the most professional of the CA forces.
I've been looking at a few builds recently, and yours really stands out for overall construction strength and quality. It says something about the CA/SD building codes.
So a few questions:
So on the pour, they popped the forms off the inside of the stem wall and finished the inside as they were pouring out the slab? yes Cool one shot pour. What was the process there? How deep are the footings? the footings are 12x12 but the excavation was 4-ft deep.
Did you pour that slab level? Sloped less than a 1/4" per foot
Is this 2X4 or 2X6 construction? Looks like 2X4. yep, 2x4
You don't need AC I assume.
Is that Hardi or Certainteed Cement siding? It's a wood type siding to closely match the house.
Why did you use those lap clips? They act as spacers allowing the siding to expand a bit.
No plinth blocks for the lights? What is a plinth block?
Any pan under the french door? It's a pre-hung door so there is a metal threshold.
The boxed soffits are nice and code I assume. I had to fire-proof the east soffit so we just made the rest match.
Why is the vapor barrier UNDER the sand? Wouldn't it do more good on top of the sand? That's were the concrete guy put it and I didn't want to risk puncturing it when I drill through the 6" slab for my lift.
I know that is common old school CA way to build but I was wondering if newer builds had switched to the barrier on top. From my reading, I probably would have made them put it on top.
When you say the excavation was 4 feet deep but the footing was only 12X12 what you are saying is that you had to get in 3 feet of heavily compacted material under the footing to satisfy compaction requirements?
Is the above picture of a Lap clip?
I did a google search on "lap clips" and all I found where a bunch of lap dance videos![]()
Any one have any more info. or links on these "lap clips" that I assume are shown in the siding picture I posted.
Oh those!!! Found those at a local hardware store (Ransom's) in Ramona. Try siding clips, spacers etc. My GC found 'em.
Ray
Try **** joint protectors - you might get some more good hits!
**** joint clips?
I've never seen them before so I really don't know what they are called. I think they may be old school?
