Gounding back to main panel with sub.
Rocket79
Kansas
I'm in the process of remodeling my basement. I have an unused panel downstairs that only has 3 leads into it. I plan on installing a 100 amp sub in it's place. The original panel was 100 amp for a dryer and A/C that is no longer used. My question to the electrical geniuses that frequent this site... do I need to run a ground back to the main panel? (difficult in finished basement). Can I make the 3 existing wires 2 hots and a neutral and add the ground with a 5/8 rod driven outside? I do understand the separation of neutral and ground in a sub, but can the ground be separate from the main?
Aceman
Eastern Oregon
The only thing you can do with that existing cable is use it for a 120 volt only panel.
If you want 240v with a neutral, you're going to have to run another proper 4 wire cable instead.
R
Rocket79
Kansas
I guess I should have clarified. This is an older house and the original panel was 220v. It has 2 hots and a neutral. The wiring into the panel is #2. Only thing lacking is a legitimate ground.
Aceman
Eastern Oregon
You don't need to clarify, I already understand you have a 3 wire SE cable feed to an unused 240v panel. You need a 4 wire cable to do it properly.
Adding a ground rod does not take the place of a 4th wire.
I know it's not the answer you were looking for but there really is no other way around it.
uggg :rolleyes:....*facepalm*
First off, grounding electrodes and EGCs ARE 2 COMPLETELY DIFFERENT THINGS! People get this confused almost everyday and I explain this on here at least twice a week.:rant:
A ground rod DOES NOT provide a ground fault path for the breaker. Grounding electrodes are for grounding lightning ONLY. A ground rod will do NOTHING FOR U HERE!
While yes this is an old feed, anytime u change electrical it HAS to be brought up to current code. Old code allowed 3-wire feeds. Now 4-wire feeds are required! With one exception, code does NOT allow the ground wire to be separate from the circuit wires.
If u will be replacing the panel, your gonna have to either: A) run a green ground wire ONLY if the feeder cable is individual wires such as THHN and DOES NOT have an outer jacket or b) run an entirely new feeder with 4-wires.
Aceman understood your question perfectly.
And BTW, ground rods are only needed at the main service and detached buildings!
justsam
Penngrove, California
Clearly updating to a 4 wire is the way to go but it may depend on your use.
As stated, you do have the makings of a very stout 120 volt feed. Depending on what you want to do in your basement this may be just fine.
R
Rocket79
Kansas
I knew that. :thumbup:
Thanks what I didn't. Thank You
R
Rocket79
Kansas
While the dryer is gas now, and 120v would be fine for now, if we ever need/have to run a electric dryer I would need to be at 240v on this panel.
Better build it right the first time.
Zeke
Electric dryers eat energy and cost money. If you do decide to get a 240v dryer you can run wire then. For now, you won't have that impetus. Only time I'd have an electric dryer is if the house was on a propane tank.
Why is that? Theres dryers that will run on propane!
