atikovi
I'm using it to walnut blast the carbon on intake valves. It came with that short white nozzle and works fine with it. But when I replace that with an 8 inch nozzle for walnut blasting, I get just air coming out. I removed the black feed hose from the handle, and there is no suction when I pull the trigger. Actually I feel slight pressure. With the short nozzle installed there is good suction.
Any ideas? Could too much pressure cause this? Compressor regulator is set to 140 psi.
