ishiboo
Astroglide. I buy it in bulk and use it in everything. I mean use it on everything.
Astroglide is water based.......so I don't use it on my ratchets.
i put some blue amsoil marine grease in a couple ratchets (out of superlube) and its a little too thick. it quietened down the teeth some, but doesnt feel much smoother. i need to order some superlube. cant find the grease local anymore, though some stores still carry the spray?
Funny story. The Jo Solution silicon lube is exiled from the house. Still gets used here and there in the garage. I might do the next ratchet I open with it just to see how it goes. Usually I use 3 in 1 but I have used super lube also. Never noticed an issue with either.Astroglide is water based.......so I don't use it on my ratchets.
60 tooth isn't that small unless you're talking 1/4 in drive. I would assume they're talking about the 80/88/+ tooth ratchets.
I always avoided white lithium grease because I figured it'd get hard and keep the pawl and teeth from meshing properly. Then I found an old unused Craftsman box head ratchet from the 50's and the original grease was only partially dried out. So I tried some Lubriplate.
Since I clean and relube my ratchets every year I don't think it'll be a problem .
So far it works fine.
I wouldn't use it on round head types though. They always get oil.
It has moly in it? That may be a very happy ratchet!I use sta-lube engine assembly lube. have had the stuff forever. Has moly and graphite in it. its like a gray grease almost. makes a world of difference
I was wandering if anyone used ATF, its cheap, thin and quite good at cleaning up gunk.
LoL! GJ has all the answers!
White lithium grease is the worst choice i've found. At this point low tooth count ratchets seem to do well on synthetic brake lube or RLL.
