Grease Gun coupler streight pull off
johninct
I need a grease gun coupler (the part that snaps onto the zerk) that will pull off easy straight ( with no side to side movement) because of tight clearance issues. Does anyone know where I can get one?
fatboy621
Central Ohio
Any farm supply store will have what you want. I just bought one at TSC that was adjustable on how tight it is on the zero. It was around 5 bucks.
bgott
Houston, TX.
The tip is threaded, unscrew it a bit and loosen it up. Too loose and it might pop off under pressure. You might need to loosen it up, stick it onto the zerk and then tighten it back up.
This^^^
Take the tip apart, clean it up so you can easily give it a half turn, off or on...
