Grease Gun storage?
fourjeepin
Atlanta, GA
I'll play along. Mine is below. Same design as most of the others, except I have a small and a normal sized gun. Works great, except I do get a tiny bit of leakage from the tip of the small gun.
I used a small section of PVC to space the tubing off the plywood to allow the bottom caps to slide on and off.
NUTTSGT
Northern Central Ohio
How are you actually attaching the tube to the wall? I can't see how you could possibly screw something in there since the one side of the tube is obviously blocking where you would be able to use a screw driver or socket??? Am I missing something very obvious?
Thanks,
-Nigel
I have a hole drill near the top of mine. I used a ratchet wrench to drive a lag through the inside into the wall.
LX-Markham
Markham, Ont.
I got one of these from Princess Auto years ago. It was cheap and works great. Love the PVC pipe idea though.
rwreuter
Mulvane, Kansas
what size is the PVC?
I built this one a while ago, all out of black ABS.
It has worked great for me!
The top cap is a loose fit for easy removal & keeps the garage dirt & dust out of it. The bottom cap is quite a bit tighter but still removable so every once in a while I can clean out all the gunge build-up.
I drilled the hose hole (bottom left of tube, last pic) on an angle so the hose would go in easy & stay securely in place. The holes in the front of the tube itself at about 1&1/2" down from the top cap & up from the bottom cap are how its mounted. The holes are there so I could get a screw driver threw to the 2 smaller mounting holes in the back of the tube. In order to have enough room for the caps to be easily removed I used 3/8" of spacers between the wall & the main tube.
However it's not my idea. That glory goes to Stephenw(member here) I found it on his site
Steve
SnoFox
FSJ B.C.
To store mine I cut the bottom off of a 2 liter pop bottle and screwed it to the wall upside down. Any leaks drain to the cap and can be emptied by removing it... :thumbup:
