I know this isn't real high tech, but what is the best route to go for a grease gun. I have a Lincoln hand pump unit, but it seems like I get more grease coming out around the nozzle instead of going into the zerk. It works much better if a second person holds the grease fitting tightly onto the zerk. I though about an air operated gun but then you have the air hose to drag around. Maybe I need to replace the grease hose with a better quality one, but there doesn't seem to be much to choose from. I am using the grease on an old car and couple of tractors. The zerks are not plugged up. Any ideas? Maybe I am being too picky, but I am tired of the mess.
why don't you just consider it part of his charm
After awhile, you will get used to it, if he sticks around long enough! He hasn't been hangin around here much lately. The one thing I can say about Elroy is he is fairly shop savvy and has shared some good shop tips. He might even teach you a thing or two if you can get past his third person schtick
Now that I am used to it, I kind of miss the third person on an Elroy post!
