IFMJohn
What grease do you guys use on your toolbox ball bearing slides?
I sprayed some Lucas toolbox buddy on the slides of my Kobalt and it started making more noise (like a metal on metal noise). You can definitely tell the difference between the drawer that I put that on and the drawers that I did not. I then pulled the drawer out and stuffed as much Extreme Pressure, high heat, Marine Grade Grease as I could in it but it still is making noise. What's the best stuff to use for the drawer slides?
It's a ball bearing slide if that makes a difference.
