Greenfield pipe cutter replacement wheel
captaindiode
NC
Anyone have a suggestion for finding a replacement cutter wheel for this Greenfield #1 Pipe Cutter. Capacity is 1/8 to 1 inch steel pipe.
Thank you.
Should match someone's standard size hub.
Some cutters even have a spare stashed on board.
C
captaindiode
NC
Box store has wheels for tubing cutters, but this is for galvanized or black iron pipe. It does look like Ridgid might use a similar cutter in one of their models.
2oolhound
BC Canada
Ridgid and Reed usually are interchangable and there is an asian brand that uses the same wheels.
genog
Silicon Valley
I always keep a couple of bigger wheels around
These are from Rigid
I am sure wheels for the smaller cutters will be as easy to find
