Greenfield Tap and Die set Logo Label Needed
EverChas
NEW MEMBER HERE.
I have a GTD SCREW PLATE set that I’m repairing the case and cleaning up the contents that I found cleaning out my Grandfather and later Uncle’s automotive shop (1940-1990), not for resale but just for my gratification and use if ever required. What I do require is a clearer photo of label that should have been on top of case. I found exact case set advertised on eBay so I screenshot label to possibly get reproduced somehow, but if someone has one out there and could provide me with a clear photo of label in photo attached I sure would appreciate it. My plan is to send off for someone to reproduce on a vinyl stick on material so I can place on case.
See best photo I have.
Thanks to all.
MAD
Western MA
I found the attached label photo with an image search. The link from the search was dead so I was only able to grab the thumbnail and brighten/sharpen a little.
E
EverChas
Thank you so much. I’m elated. I knew someone out there would come thru for me. I have searched and searched sites and eBay etc. Garage Journal came thru in a day. You collectors are awsome. Now to get the photo made into a decal or sticker. Thanks again. Charlie
MAD
Western MA
Glad that one looks like it will work. I'm attaching the original and my edit again as files, in case the inserted image process lost resolution. Someone using better software like Photoshop etc might be able to get an even better image.
E
EverChas
Thank you again. I’ll let you know what the final product looks like after completion.
  • Like
Reactions: MAD
jmwood
This is an original Greenfield Tap & Die Machine Screw set. Does anyone know where to find or already have a clear image of this box or logo and any other information like year of manufacture please
You might check these URLs:
Greenfield / Greenfield Tap & Die Corp., Greenfield, MA / est. 1912, merged with United Tool & Drill 1958, renamed United-Greenfield, merged with TRW 1963, acquired by Kennametal Industrial Products Group 1992 / taps, ties, screwplates, brace sockets / "Little Giant" / patent 1048921 Dec 31 1912 Frederic E. Wells & 1052313 Feb 4 1913 Addison B. Carll / http://alloy-artifacts.org/other-makers-p2.html#gtd / http://vintagemachinery.org/mfgIndex/detail.aspx?id=402 / http://chc.library.umass.edu/greenfield-historical/category/greenfield-tap-die/ / https://www.westfield.ma.edu/histor...ads/2018/06/Ducharme-summer-2006-combined.pdf / http://americancenturies.mass.edu/c...id=18426&img=0&level=advanced&transcription=1 /
and
Greenfield at International Tool Catalog Library
