Greetings and floor plan questions
TurboDogsDad
Palisade, CO Cornville, AZ
Hi folks,
I'm working my way slowly into retirement and project building in AZ. First project (after the new shop) will be a Miata turbo drivetrain and suspension into an old BMW 2002. Before I can do that the shop has to be finished. It's dried in 45'wide x 50" deep, stick build with tall enough walls for a second floor loft somewhere down the road. Right now we're locating wiring and figuring out floor plan. Is there anywhere in this forum specifically for floor plans? Thanks!
HOTFR8
Castlemaine, Victoria. The Hot Rod Centre of Austr
Welcome to the GJ. Can I ask you to update your location on your profile as you will find that may be of great help to you in the future. You could ask about floor plans in General Discussion or if you want comment on your own post something up in the Gallery.
drivesitfar
TDD: not sure there is a section specifically just for plans (probably should be one though) so my suggestion would be to go in Garage Gallery and start reading the threads where there are similar garages to yours and see how they designed theirs. if you have questions asking them on those threads might get you some good answers.
here's a thread where a member with a stick built garage is putting in a loft that might help you some.
http://www.garagejournal.com/forum/showthread.php?t=352976
welcome to the forum and hope you like it as much or more than i do.
