Snakebyt
co worker cracked a gp socket, took back to dealer and they replaced no questions asked
I already wrote GP off when it was posted that the warranty is only valid if purchased through an authorized dealer. Amazon Is not an authorized dealer but is the easiest place to purchase their tools. A company should either warranty their products or not. I can't stand playing games.
The problem is this you can not have it both ways...
One guys screams oh my Lord the tool is so expensive, "what $40.00 dollars for that small tool, but it has a super good warranty period.
The next guy buys the entire set for $40.00 and screams oh my Lord the thing is only good for three replacements period.
You can not have both, just the way things work today; buy expensive and cry hard the first time or buy cheap and cry all the time.
Yes you can. Buy used top of the line tools like on Ebay then warranty as necessary.
How often do you plan on breaking tools? I have found that tools typically break when abused......
Home Depot sells at least a few Grey Pneumatic sets, (Maybe only online, I have never seen any in any store) does anybody know if they are an authorized vendor? I sent Grey Pneumatic a dealer request and got nothing whatsoever back...
take a look at the following link:
http://www.gpsocket.com/warranty.phtml
In part it reads if the **** dealer will not help you and I quote they must send in the set and grey will look at it and make their determination.
So op before you go off the deep end and kill it for everyone, go back to your dealer with a copy of the above link and make the dicks return the set to grey.
Nope, not replacing the entire set. Pointless to send it ALL back.Sets: Warranty on sets applies to the individual parts within the set. If one part is deemed under warranty, we will replace that part and not the complete set.
Curious: Was this T27 an impact socket? Using a hand tool with an impact driver produces shock loads the tool may not be designed to accept. If this thing isn't impact-rated, you misused the tool.I guess using a 1/4 drive electric inpact on a 3/8 inch T27 torx is too much power.
It was an impact socket used with my dewalt 1/4inch impact. It snapped on the first hit of the hammers. This is why I suspect it was just a void or some other material failure. I can't imagine a bit, even from the shady Chinese tent at a swap meet, being that weak.Nope, not replacing the entire set. Pointless to send it ALL back.
T27, T47, and the goofy prehistoric-not-really-Torx GM door striker/seat belt bolt are the sizes that need the highest quality. You're nuts to buy these sizes in anything other than the best available. The usual sizing-by-5 fasteners (T10, T15, T20...T60, etc) aren't the trouble the "7"s often are.
Far as I know, there's only one source for the prehistoric GM door striker/seat belt tool--Snap-On PSTX500E or the previous versions. Snap-On calls it "Socket Driver, Power, TORX[emoji768] (GM[emoji768] Style), T50" but it's NOT a T50 Torx. Don't use a T50 on this "special" fastener, or use the "GM Style" T50 on a regular Torx fastener. You WILL damage the tool, or the fastener, or both.
Same here, sent them an email while trying to locate a local dealer but no response from GP and that was 3 years ago.
I moved on and bought Sunex, Tekton, Snap On and some SK sets.
Ever been in a heat treated shop? They have baskets with hundreds or thousands of parts in heat treated at one time. Center of basket gets a slower quench. Parts at start of shift get a faster quench due to colder bath.
A 20°drift in tempering oven changes toughness. Are they modifying the atmosphere?
Did a secondary or tertiary supplier deliver slightly out of spec alloy? Higher or lower than spec causes problems.
Sometimes the variables stack and you get bad parts. Warranty handles the tiny percentage of outliers.
Same reason I decided not to go with GP.
I am thinking of getting some Sunex impact sockets. I imagine that it would be rather difficult to warranty GP stuff through Home Depot. (If they would even do it)
I would never, ever not buy a tool because of a warranty and if a company will back it....let alone based on an internet posting.
Honestly I'm going to pause on GP now, too.
What's that T27 cost them vs what they're losing in sales here? Yes there are abusers but a little goodwill can win you a customer for life. OR just don't offer a warranty, that's ok too and everyone knows where they stand from the start.
I've seen Tekton and Sunex praised here but let's not forget AP (Astro Pneumatic). A single PM on this board will usually get the ball rolling....
Torx are just the worse case scenario for warranty issues snappy golds are the best Ive ever used but even they are no match for jeeps used in the rust belt.
heat or welding a nut onto the awesome torx fastener is the usual solution.
