Grinder can't keep up as a buffer?
AmericanMechanic
Hello,
I have an old grinder which I restored a while back and I believe is a Baldor that was sold as a Rockwell 50 years ago (the actual name plate is gone).
It's a 6", I believe 1/3 HP. It's strong when grinding, but I put a stitched buffer pad on it and anything but the very lightest touch brings it quickly to a halt.
I realize buffing takes a lot of torque but wondering if other folks grinders struggle when used as buffer, or if my motor needs work (brushes, etc.).
Thanks
torqueman2002
You're right, buffing requires more power/torque than grinding.
I don't think yours will have brushes. I expect it is an induction motor with a rotor and not an armature.
I have a 2-speed Baldor buffer made for and sold by TP Tools.
Baldor Buffer
8453 - 33TS
HZ: 60 WT: 67.000
HP: .75/.5
VOLTS: 115
AMPS: 7.8/7.4
RPM: 3600/1800
lazer50
east central indiana
I have a 1hp grinder 6 inch grinding wheel one side buffer opposite. It does what yours does also very little pressure bogs it down. But it grinds fine.
Know Wosad
It takes a lot of *** to buff. Mine is a 1 1/2 @ 3450 spinning 10" buffs. I consider it minimal. I wouldn't go after a car bumper or motorcycle exhaust sized piece on it.
My buddy runs a 5 HP with about a 15-16" buffs 2 1/2" wide at his chrome shop.Scary machine if it grabs the work piece !
A
AmericanMechanic
Thanks guys. I'm trying to polish a vise handle. I may try some real fine sandpaper to get close and leave only the real polishing with a loose cottom pad for the grinder to address.
