I have an exhaust manifold that I need to hone out and clean up a little bit. It is cast iron and some of the welds needs to be cleaned up on the inside of the some of the ports.
What type/brand of grinding stones should I use? What holds up longer than generic dremel stuff?
I need to gasket match the ports and clean up a factory weld that is impeding some flow.
