My garage burned to the ground recently, and I'm currently rebuilding. The slab is structurally sound, but looks bad and the surface is badly "pocked" in many places.
I have a contractor who is going to cut around each problem area to about a ½" depth; fill the void with an epoxy filler; and then grind the entire slab. He's the same guy that does the local Home Depot's/Lowe's/Kroger's/etc -- and the results look pretty good.
I'm generally convinced that grinding the slab is the best solution; but I'm wondering about the epoxy filler material. How does it hold up? How does it look after grinding? And should I plan on staining the concrete/epoxy, to get a consistent look? Anyone have any experience with this? Thanks.
