pauls_workshop
Hi Bruce27834, yes you would want to diamond grind the floor to get off any sealer before trying to apply epoxy on top. No epoxy would do well on top of a sealer. I just had to do this for my project. Epoxy needs a rough surface to stick, like a 80-120 grit sandpaper ideally. A primer is good, but epoxy wants "an epoxy" primer, not something else. So think of the primer as just another layer of the epoxy. Could be a thinned coat or a cheaper water based epoxy though. To avoid your tire peeling, use a good 100% solids basecoat and diamond grind it first. - Paul
