Grinding results
Dave5817
Should I expect the floor to be completely uniform after using the EDCO. Seeing some dark spots that don't seem to grind as easily. Some seem like low spots
Take a look if you have time.....
Armorpoxy
Uneven finish enter grinding is normal. As long as you have a good surface profile you should be fine. Make sure you are using a primer on a grinder floor.
