Verg
I picked up a Calder 22 stone dresser that has some worn/broken parts. After alot of looking, i could not find anything about the company or replacement parts in the proper size. I don't believe the cutters currently in the cutter are correct; The cutter stack width seems very small relative to the dresser opening combined with a fair amount of adjusting washers that did not look correct. I have been looking at the Desmond grinding company website (http://www.desmond-stephan.com/) to see if there is something that looks interchangeable with my dresser but i simply don't know. Any advise for finding proper cutters would be much appreciated!
The measurements off the calder 22 are:
17'' long
2-11/16'' between the inside of the open end legs
2-3/16'' at the smallest distance of the open end (dirt may be making this more narrow then it really is Needs a cleaning!)
2'' current cutter Dia
1-11/16 Current Cutter stack thickness
The shaft the Cutters ride on has broken; i plan to make a new one once i figure out what cutters will work. Pics below I can get better ones if need be.
I plan to use the dresser on my new US electrical Model 20 grinder (hopefully picking up this weekend) 14''x 3'' stones.
Thanks in advance!
17'' long
Thanks in advance!
