2ndGearRubber
I know these are rather new, the dual drive style bits in 1/4 drive. Grip edge advertises these as "7/16 (11mm)" driven end via a wrench, IIRC 11mm was the size in video on the bit. 7/16 is around 11.1mm.
I used the 1/4 astro 78345, which the Grip Edge bits go into and lock securely. However the VIM FRW11 doesn't work. Granted neither of these brands nor Grip Edge claim that they're compatible. The VIM will not fully accept the bits, and you need pliers and some effort to remove them if you try.
I think these are going to be great, I'm sold on Grip edge for hex. Just wanted to add this information if someone wanted to use these with the Astro handle.
Then again, Gripedge might want them to work only with their wrench if they offer one.
