OP is in a wheelchair so a full sized mill will not work for him. He needs something that can be mounted on a low bench.
****. Now I remember his earlier post. There is a little Rockwell I mentioned, but finding one and moving one won't work. These mills you mention are not really table top models. I think you should try the SIEG x3/grizzly g019. This has all the problems I discussed earlier, but is less expensive and smaller without being super limited work envelope wise.
Here's what you will need to run this mill:
Step 1, get a good trustyworthy surface plate. 12 X 18 min.
Step 2, get decent (I.e. not chinese) dial test indicators. You'll need 2, a thousands and a tenths model (or their metric equivalents) I actually had some of the cheap Chinese indicators and was okay with them, but they have non std dovetails that don't fit Noga arms etc.
3, surface gage with fixings to mount the DTIs. Also Noga spindle arm and small Noga mag base.
4, spotting paste, feeler Gage's, abrasive stones, files, etc
You'll have to completely disassemble the mill and inspect each component with the tools above. Granite parallels can be helpful straight edges for checking dovetail surfaces. You may not be able to remedy the problems, but knowing where they are and their magnitude is helpful. There will be places where you can make adjustments or add shims. And these machines are typically frought with dirt and filth, so a good clean is in order anyway.
Last, the table screws are typically so vague and inaccurate that a DRO is a practical necessity. You will grow to love it. There are out of the box models, and models you can make yourself (shumatech). Budget in a three or 4 axis system quill being fourth axis).
So if you follow me, my recommendation is a smaller cheaper mill for the accessibility, but the added expense and hassle of inspecting and managing the Chinese dovetails. Of course you can do good work with a bad machine. And the skills you learn inspecting and working with a less than perfect machine will be valuable and worth learning.
