Groaning Vise
Bryan Burns
Grayslake, Illinois
I have a 254 264 Prentiss Bulldog vise that "groans" when I'm closing it. This occurs only when it's about 2 or 3 inches from the fully closed position. Is there a way to fix this? I assume it's some type of alignment issue.
If I recall correctly, my Desmond Simplex (which is in my cold garage) does something similar but it doesn't bother me as much.
Mark in Indiana
Southern Indiana
Bryan:
Just a shot in the dark.
Have you removed the dynamic jaw from the stationary body? Cleaned & lubed the spindle/nut?
When you clean those items, look at the condition of the threads.
Bryan Burns
Grayslake, Illinois
Bryan:
I cleaned them but I need to inspect the spindle nut more carefully. I think it's a little wonky. Thanks for the tip.
Carla
MEMBER EMERITUS
Bryan,
A 'groan' would be a 'resonance', caused by a 'stick-slip' condition between moving parts. Its usually the symptom of a situation where parts should be oiled, but are dry....the remedy, obviously is to clean, polish, and oil the parts.
Sometimes, a working surface will have become rough due to 'galling', a breaking-down of the smooth finish needed where parts interact with one another. The remedy for galling is to polish the affected surfaces of the parts, and keep them oiled in future.
It is entirely possible that the main screw may have become bent......have it out and check it on v-blocks, straighten as may be needed.
Another thing to check for on a Prentiss vise would be the fit of the main nut in the fixed jaw casting. The nut should be free to 'float' laterally to align itself with the main screw. This compensates for factory error in the castings.
If the pin securing the nut has been driven hard against the nut, so that the nut can't 'wiggle' a little, try loosening it with a few raps on the front of the nut, using a brass or copper drift and a fairly heavy hammer.
cheers
Carla
rusty65
Pekin,IL
Oil where the screw knob meets the moving jaw. Also behind the collar that keeps the screw from backing out of the jaw.
drivesitfar
BB: Prentiss vises are also known for the back of their dynamic slides splitting mostly from abuse. while i don't think that is your issue and one of the other fixes mentioned should solve your problem have you pulled the dynamic all the way out of your static yet?
good luck
Bryan Burns
Grayslake, Illinois
good luck
Actually, I found that the fixed body has cracked at the spindle nut keyway on both sides as shown. That's probably the cause of the noise. If I put my palm down on the end of the slide while turning the handle, the noise goes away. No crack in the slide the Prentiss' are known for.
I put the vise on Chicago CL today for $55 dislosing the cracks.
https://chicago.craigslist.org/nwc/tls/6475964819.html
BB
