Ground Hornet Nest
Ralf11
I set a trap with sugar bait, but am curious if that just gets the workers and if I need to call in an exterminator to kill the Queen?
- it's downhill below the garage - I figured you guys would know even if it's not strictly related :bowdown:
86turbodsl
i did another one this year. if it's not around anything flammable, i usually do gasoline and a lit torch. Around dusk. There was a giant pile of dead ones in the morning. A few stragglers for a few days, but that nest is gone.
Garry
East Wenatchee, WA
Wait until dark (All of them will be in the nest) pour a quart of gasoline down the entrance and put a brick or something like over it. No need to light it, by morning every one of them pests will be dead by the fumes. Guaranteed! It works every time! Don't do it in the daylight, they won't all have returned to the nest till dark!
-Garry
Kaizen
New England
Location would be helpful. In cold places they will be going dormant soon.
Gas is usually first go to. Vapor gets through the whole nest. Fill it in after of others will use it next year. No sense working when you can move right into a vacant home
KEH
A quart of gas is too much and is dangerous. 1/4 cup is enough. A brick on the entrance is a good idea.
KEH
Innovate1
KEH
That was my first thought. A quart is way more than needed. I would have guessed a cup was more than enough. Wait until dusk so they are all inside. Then quickly dump it in and slap a brick on before any can get out. You could even put some screen down first, then dump in the gas if you are worried some may escape.
58Yeoman
Central IL
Thanks. If I ever have a ground nest, I'll remember the screen. We've had three large nests in the trees at my place.
mrvm
PA
Got them stinging devils good after getting stung while mowing the lawn. D13072EC-E2B1-49F3-9DDF-6D7ED046F2CE.jpg
BillK
Beautiful Southern Maryland
Go to home depot and buy a can of the spray made to kill them. Thats what I did last time. Cant remember what brand it was but it worked just fine. You wait till dusk like the others said and then you spray it in the nest. Its like a foam and any that do come out will touch it and get killed.
acer66
Western North Carolina
I do the big mouth jar thing, at night put it over the entrance secure it with some dirt and watch theme exhaust themselves going in and out of the jar.
from the nest.
One time I did that with a bigger nest and the jar was full with them and like the idiot I sometimes can be I was contemplating what would happen if I tip it over but fortunately common sense saved me.
That nest was also the only one that started making a second exit but another jar took care of that.
Approaching a nest at night does not guarantee safety though.
I did one at like 10pm and they were not having it but fortunately I was in full bee suit so no harm.
crazylunker
Connecticut, Trumbull
I trigger a raid house fogger can next to the opening and immediately invert a 5 gallon bucket over the can and the nest entrance with a brick on top.....next day no activity
rlitman
Long Island
KEH
Yes. It's the fumes that kill them, and the fumes sink into the nest, since they're heavier than air. However, gas also kills plants, so if you don't want a dead patch, this isn't the best answer.
The best product that HD sells by me (this may vary by region) is Spectracide Pro. It's a big white can with black lettering. That however is not a foaming product, and for that matter, my local HD doesn't sell any foaming wasp sprays. My Ace does. The nice thing about the foam is that it seals the entrance while you're spraying (if you do it right), which gives you time to escape.
I usually just apply a couple of teaspoons of Delta Dust to the entrance at night and let it do its work.
...Approaching a nest at night does not guarantee safety though.
Yeah, there are usually some guards hanging around the entrance at night. During the day, pay attention to the location of the sun. They fly out the first few feet directly oriented towards the sun, and if the run into you there, you'd in for a surprise.
OneOfEm
There can be a 2-3 guards at the entrance at night, so bring some spray when you start.
I've used a shop vac with a couple of inches of soapy water before with great results. I started the vac right before the sky started turning light, and by noon they were all gone.
Eventually the queen will come out to investigate.
WNYflyer
Lockport, NY
Looks like one of the local skunks took care of mine. Now I need to fill in the hole so I don't break an ankle. Doesn't help that the location is the site of a previously taken down tree were the roots are now decaying and thus the ground is subsiding. Going to need to probably dig it up more than anticipated and bring some dirt in.
pi_guy
N/A
I use brakekleen as my personal defense. Did the HD chemical thing at night did not work the first time. I found they had tunneled under a section of wood so when I turned over that wood I found the mother lode. So after the second chemical assault I shoveled the remains of nest into plastic bag and left the scene. Next morning plastic bag was ripped nest gone no dead hornets.
Over the next few days I had a few come back and look for nest but brakekleen got them.
R
Ralf11
as OP I appreciate all the responses, but the nest has a long slot like entrance under an exposed root - I could block it off with a sheet of plastic - maybe
It is 150 ft from any electricity so no shop vac answers
Again, my question is whether a trap is likely to capture enough workers to wipe out the nest...
rlitman
Long Island
...Again, my question is whether a trap is likely to capture enough workers to wipe out the nest...
That's easy. Absolutely not.
Trapping workers will hardly have any effect on the overall nest health. It will always be churning out workers faster than a baited trap can collect them.
Now if you had a bait station with a slow-acting non-repellent insecticide that they could bring back to the nest, there's a chance it would work.
Garry
East Wenatchee, WA
Like I said above, wait until dark and pour a quart of gasoline down there and cover the entrance as best you can. It's outside in the exposed air, it's not dangerous as long as one doesn't have an ignition source with the gas prior to pouring it down the nest entrance! A 1/4 or 1/2 cup will likely not be as effective. I have done many of these when we had acreage and it was 100% every time. A trap will not work!
gfd_703
west tennessee
You people are no fun. Around here it is pour up to 1 gallon of gas down the hole and wait at least 30 minutes for it to complete vaporize. Then pour a gas fuse at least 200 ft and light. It will blow like dynamite. Not recommended for urban settings or near anything but open land.
acer66
Yeah but I grow stuff in the garden and I have not acquired a taste for gasoline flavored food yet.:willy_nil
PugetDude
Superstition Mountains, AZ
Had a basketball sized underground nest in the side yard at our cabin this summer; neighbor called in a exterminator since it was actually closer to his house than ours. Exterminator arrived around noon the next day, a skunk had completely wiped out the nest that night. He told them it was the second one in a row that day. Skunks must be really hungry this time of year, the nest was completely excavated and scattered.
I was prepared to wipe it out with a big can of foaming wasp spray and a couple of gallons of soapy water. Fire danger is too high for gas.
Don1357
Palmer, AK
On every person's life there are certain weird and funny things you see that you never forget, no matter how old you get. One of them was when we moved into our new house. I was on the porch taking the views when my daughter comes running from the tree line acting like he was having an epileptic seizure while going at full speed. She then proceeded to, while still running, take her pants off in the middle of the lawn and then rush past me and into the house. Yup, she stepped on a ground nest and knew nothing other than she was getting stung and there were bees clinging to her pants.
rlitman
Long Island
A spoonful of Sevin dust will kill them.
BTDT. It does, but slowly (think days, not seconds), and only if the Sevin is fresh. I've had Sevin that was on the shelf for a few years not work at all. My wife was also stung at night by a yellow jacket that was as white as a ghost and that looked just like a moth because it was so thoroughly coated in dust. It would have been funny had she not been stung.
RoscoTom
Northern Michigan
When I lived in the city, I found a ground nest while mowing.
This was the old days, I had an old 2 stroke LawnBoy push mower.
I got stung a couple times, and took off running.
I left the the mower running wide open between the houses, and hopped in my truck.
I drove a couple miles to the hardware, stocked up on spray and went home.
The mower was howling away, just like I left it.
I emptied both cans of stuff, then retrieved the mower.
I found out later that the busybody neighbor got annoyed and went over and tried to shut the mower off and got stung a couple times.
They are nearly blind at night and you want to kill them all so wait until they are all in the nest at night not on a full moon like now.
Then wear thick winter jacket and overalls, gloves. You can dig up the nest and spray them all without much worry because they have no idea where to go for and can’t see you. The guards will buzz a lot to scare you but that’s about all they can do. Very easy to kill a nest. I’ve destroyed yellow jackets in the South this way that can actually kill adults.
BigGarage
Just south of Detroit, MI.
This would be my choice too but I'd be remembering Al Bundy's words while I did it; "Bud, if dynamite was dangerous do you think they'd sell it to an idiot like me?".
Dennis
NUTTSGT
Northern Central Ohio
Any type of "bees" that I have used it on, have been dead by the next day.
Maybe I just have better luck ? :dunno:
rlitman
Long Island
Maybe. I do think that batch of Sevin was just too old to be effective. 5% Sevin dust is also 95% diatomaceous earth, which is also insecticidal, but is much more slow acting. The nest in question was still dead within 48 hours.
But I've also seen Drione dust drop wasps right out of the air (and Delta dust is nearly as strong), so there are some rather fast acting dusts out there for the riskier situations.
NUTTSGT
That's quite possible as well. Could also have been a bad batch, beginning or end of the run.
Most of the time, i fill a tube or hose with Sevin dust and its connected to a compressed air source. It carries through hive rather than leaving it to be carried in by those coming back.
redmondjp
Redmond, WA
Besides skunks, raccoons also dig up and eat the nests. I had one in a rotten tree root a few years ago, similar to the OP's situation, and I was pondering what to do about it (was in an area where I mowed right over the top of it which obviously is not good). Then one day I walked out to the nest, and the ground was ripped open and everything was gone. I had to do some digging online to figure out that raccoons will sniff out the nests at night and eat them. That upped my respect for raccoons by quite a bit.
HaiKarate
Seattle
We get ground nests on our property about once per year. I boil a pot of water on the stove after dark, walk out there (Carefully) and pour it down. Cooks/drowns them and I have yet to have one come back.
Bretny
Dutchess county NY
I have used a weed burner set over there hole and a long stick to stir them up. I also used about 1/2cup of dish soap in the hole then stick the garden hose down it. It foams up and they drownd.
John in OH
SE Ohio & Eastern Virginia
Although it's an environmental no-no, I locate the entrance hole during the day. Then, just after dark I take an old glass Coke bottle, fill it with gasoline, upend the bottle, and stuff the open end into the hole.
Success rate is near 100% with minimal turf kill.
