Ground pin up or down?
Norcal
Does it matter when you cut the ground lug off the plug strip to use in your 1930''s 2 slot receptacles? :lol:
On a serious note, as long as it's wired correctly (Silver to white is all right, and black to brass won't kick your ***) you're fine.
What if it's ceiling mount plug? Should the ground be to the north or east, or south and west?
Just be glad we're not in the EU... I could go on at length between 8 amp, 16 amp, and Schuko sockets... and not even broach 220 vs 230 vs 240...
The EU settled the 220,240V situation, by harmonizing everything at 230V.
jdieter
Northern Indiana
Worked a ton of commercial construction and on one of the jobs the supv. wanted the receptacles below waist height ground up and above the waist ground down. His theory was nobody pays attention that the ground pin is longer and pushes an attachment plug in exactly perpendicular to make the ground connection first. He explained his scheme provides the safest way to get the ground established before current flows. Every other job and everything I've done for my self, ground down.
Norcal
Didnt say there was.
Just saying all the years I've been wiring that's the way we've always done in all the states I've ever worked in is all.:beer:
My point is that it’s purely personal preference or job specs, it’s beating a dead horse:deadhorse
PartsGuy
Jamestown, NY
What really bothers me is a light switch that has been installed upside down.
AMEN, brother! My entire house is wired this way, and it drives me freakin' nuts! If I wasn't always so damn busy out in the shop re-organizing my tools, I'd do something about it, too....
rbrock
Hills of Ohio
When I started my new house 5 years ago (still working on it) the local code here in Ohio was ground pin up. By the time I got my inspection done it had changed back to ground pin down. The inspector didn't care. So far I have only changed the outlets that have directional plugs so the cords don't point up. Eventually I will change the all back to G.P.D.
yeldogt
I do tall baseboards -- so mine are horizontal in the baseboard.
have done 36" switch hight in my last two projects ..
6PTsocket
I just emailed Hubbell and asked them why their catalog, ads, instruction sheets, labels, stamped writing on the mounting brackets and molded writing on the back of their duplex devices all seem to favor ground pin up. I got a quick reply and it was one of the reasons I had heard before. If the plug is not fully seated and something conductive drops on it, ( like a metal cover plate) it is better caught by the ground pin rather than shorting the hot and neutral. You may think it is improbable but that is Hubbell's reasoning. Mabe I should ask Leviton why they do it the other way.
6PTsocket
Apparantly that is the norm in Europe. They did some electrical work in the office building where my wife worked. They had some guys from Poland doing the work and all the light switches went in up side down. I am sure that is the way they had always seen them installed. Working as an electronic tech , I remember a piece of British test equipment made by Marconi. The power toggle switch was up for OFF, down for ON. I thought it rather strange at the time. If you have 3 way switches around your house, it can end up either way
MikeF2316
Thornhill, ON
That's nothing. You know what's worse? Alternating switches in the same box. In our old warehouse, when we moved in, there were 2 pairs of 3 way switches for the lights, one pair by the door to the offices, one pair by the rear door. One switch did aisles 1,3 & 5, the other 2,4 & 6. But in the both on or both off positions, in one of the locations one switch had to be up and the other down. Drove me crazy, so bad I came in early one morning and turned one of the switches around!
egdede
... What really bothers me is a light switch that has been installed upside down.
Yeah, me too. Sometimes the kitchen light by the backdoor is upside down, and sometimes it's not(?). Same thing with the kitchen light by the den.
gtae07
Fayetteville, GA
We bought a house at the beginning of this month. It was built in 1998. Every outlet is ground pin up. Not a problem really... until you have a device with a low profile plug that assumes ground pin down.
Oh, and all the switches in the kitchen are in really strange places. If it weren't such a PITA to move them I'd fix that.
Codyboy
S.E. TEXAS
here they ground pin is normally down.
having said that I did a fire job where the cause of the fires was; the homeowner had removed aluminum stair nosings in preparation for new flooring on the steps to the basement. he laid the nosings on top of the old latch close fridge in the basement.
over time the nosings fell off the back of the fridge, the fridge plug was partially out of the receptacle, one of the nosings fell behind the gap and started to spark. caught the wood paneling on fire & fire resulted. house was almost total loss.
had the ground pin been at the top, the nosing would not have touched the hot blade & fire wouldnt have happened.
Now adays, I suppose an arc fault breaker would have saved the fire too.
Zinsco or FPE breaker didnt trip?
I'll only ever install ground down because it looks right and is right.
Also all the 90° plugs I've seen have the ground pin down and the cord hangs down accordingly.
As far as a metal cover plate falling down and balancing on the ground pin is a good way to cause a shock. A person sees the loose plate , grabs plate and swings it into the hot blade.
Would be better to let the cover plate fall across the hot and neutral and just trip the breaker.
txvwnut
Bedford, Texas
I was in another discussion about this topic and was told the ground pin goes up. The reason being if you remove a plug and there's something conductive laying on it that you don't see it will hit the hot and neutral and create an arc issue. I took as good advice and thought what's the likelihood of that happening. Well turns out it was pretty good. I have a receptacle that is close to my lathe and when I went to unplug something there was a metal chip string that I didn't see when I pulled the plug and got alerted to it by the rather large arc and spark. So now that plug is rotated so the pin is up with the expectation of any form of a metal chip would fall away from the hot leg if it were to happen again.
rd65
Granite Falls, WA
What about more important things, like which way to put the toilet paper on the holder. :)
That depends on location for that particular toilet. Really.
I did install the outlet for my shop sink water heater with the ground pin up. I was thinking that I may store short pieces of scrap metal under the counter.
dave*99
Coastal NJ
Can you reach the lathe from the toilet? Turn and burn. Or use your parting tool and farting tool simultaneously.
minke
fly over country
My 1992 house has ground-up sockets. (No, no grinder here.) It is annoying when using a
lamp timer or kill-a-watt power meter because their displays are upside-down.
Steve_P
Ground pin down. I understand the theoretical justification behind it going up, but the chance of "the plug was partially out, and I dropped a butter knife...." is a million times less likely than all of the Victoria Secret models showing up at my door tonite to endlessly pleasure me. If we used the same statistical justification as "ground pin up" for everything in our lives, we would never leave the house on even a sunny day because the chance of being struck by lightning is greater.
All of my three prong right angle cords are set up for the ground to be on the bottom with the cord being on a ~45* angle.
sparky 1971
Central Iowa
And here’s a link to the patent: https://swlattorneys.com/toilet-paper-patent/
I keep it on my phone as my wife is an under person and requires “proof” of why I turned the roll around.
Kinda sad we’ve been married so long that this type of thing is all we have left to fight over.
At least your wife hangs it up. Mine thinks the best place for TP is the side of the bathtub.
