Ground Rods on detached building
Skooterj
Indiana
I know each building is supposed to have its own ground rod(s). But what if the buildings are really close. Like at my old house, the detached garage was only 4 feet away from the house. And the two panels were essentially back to back. The house panel was on the south side of the house, the ground rod for the house was in the space between the two buildings below the meter base. The garage panel was on the North side of the garage. Both panels were fed directly off an external disconnect. The house was old, the wiring was from the 1950's. But the panels had been updated in the early 2000's. There was only one ground rod. Should the detached garage have had its own? Like 3 feet from the other one?
mike93lx
Richmond, VA
Detached is detached. They both need ground rods connected. Whether they can use the same, I don't know. I'd probably tie them all together if it was close enough
u2slow
BC
I believe NEC requires them for every detached building, whereas CEC does not. It's a regulation thing.
Skooterj
Indiana
What if they was a covered walkway attaching both buildings? My old house did not, but we thought about adding one.
mike93lx
Richmond, VA
I would expect that to be considered detached. My guess on the definition would be sharing walls.
Is this just an academic discussion or are you trying to get out of driving in another rod or two?
BillK
Beautiful Southern Maryland
It might depend on when they were built. I know when I built my detached garage in 1979 I ran a four wire feed from my main panel in the house and the garage sub panel does not have a ground rod. It passed inspection that way and I am pretty sure that at the time the ground rod was not required with the 4 wire feed.
Skooterj
Indiana
Just academic. I don't even own the house anymore.
u2slow
BC
Driving extra rods that close to each other is academic. Nonetheless it may be required....
jmdirk
Actually I think CEC forbids it. Just went through this with my electrician getting the subpanel installed in my new garage. Subpanel needs to be bonded to main panel.
Terry D
St. Louis, MO.
That would be attached. The two buildings are connected making it one building
u2slow
BC
Also, attached and detached isn't as cut & dry as one would think. Depends on who's asking and their definition.
dcg9381
Austin, TX
Someone explain it to me like I was 5. I understand the NEC requires it and it's code. Not arguing at all. I'm largely asking what the point is if the panels have ground wires running to the mains? I assume it's for an extreme excess of ground seeking current - IE lightening strike, etc?
mike93lx
Richmond, VA
The ground running to the main is not where you want to dump the energy from something like a lightning strike
Wylie has a great write up on grounds in a sticky here
LOW1
ontario
When we rewired our Ontario camp we were told that we could have only one ground rod and it must be for the main panel. Sub panels in the “bunky” and boathouse ground back to the main panel,
The electrician said it was to prevent grounded current from running between multiple grounding rods.
I find it interesting that the Ontario code was so different than most state codes on this point.
walrus
Maine
That's the whole point of a ground rod. Gives a safe path for current to dump to instead of people during things like a lightning strike or short
Seems like more ground rods the better for a lightning strike. Hopefully fuse or breaker clears a short.
u2slow
BC
What we learned in trade school is there's expert engineering and safety arguments of which is method is best. Both have pros and cons. CEC chooses one side. NEC chooses the other. Neither is wrong except within the context of their respective regulations.
next time check the electrical FAQ's sticky. you might just find your answer there. specifically read post #4
And the ground doesnt seek current. nor does power plant generated electricity seek the ground or return to the ground. they return to the source.
that makes no sense at all. what is grounded current?
are you referring to FAULT CURRENT?
if so, fault current doesnt go to ground rods or run between ground rods underground. ground rods are NOT for clearing fault current.
Fault current runs on EGCs that are bonded to the neutral in the main panel.
the electrician that told you this doesnt know what he is talking about... smh
RivennHewn
PNW
Ground plates?
These new, or am I just behind the times?
