matt151617
I just ditched DirecTV, and attached a small OTA antenna to the dish mount. When I checked the wiring, there is a ground block installed near the wire's entrance to the house, but the ground wire is not attached to anything. Inside the basement I attached a coax surge protector with a #10 wire and a splitter with a #12 wire to the #6 ground wire coming off of the panel, and going to the water line.
Obviously the antenna/mount need to be grounded, but they're on the complete opposite end of the house from the main panel/mast. Do I have to run a wire from the ground block all the way to the #6 ground? Can I attach it to a water pipe? Or should install a ground rod specifically for the antenna? I also have 2 buried ground rods for a detached garage within 20 feet, if that's an option to tie in to.
