Hi all,
I am currently wiring up my workshop. I have done a fair amount of electrical work in the past with Romex, but this is my first large project using armored cable.
I have the main panel on the outside of the building and this is feeding a 200 amp subpanel on the inside through a section of PVC conduit. I understand that typically I would need to separate the neutrals and grounds and remove the bonding screw in the subpanel. But in this case, I am using armored cable that does not have a green conductor, only the bonding wire, so there will not be a ground bus. If I remove the bonding screw from the subpanel, how is the ground maintained back to the main panel? Would I need to run a separate ground line and ground rods for the sub panel? Other people have suggested that I bond the two panels together with a ground wire, but this seems like it would be the same thing as leaving the bonding screw in place... or would it?
Just trying to do this the safely.
Thanks!
Doc
Thanks!
Doc
