They most certainly CAN BE.
And from where, exactly, do these "electronics and sound systems" get their power?
If there is an induced (or leaked) AC current on the neutral (or worse, EGC) due to a ground loop in the building's wiring, that can EASILY play hob with the operation of said "electronics and sound systems".
Not to sound rude, but you seem like the typical sparky who thinks ONLY in terms of building wiring (and perhaps secondarily about the safety issues specific to that very limited scope), with no regard to what is OPERATED off that building wiring.
If a ground loop in the AC ground is causing issues with AV equipment....then the power supply in the AV equipment is either a POS and/or you have the commons in your AV audio hooked up wrong.
A good AV designed system should be totally independent of any earth ground....in other words, there should be no change in quality if the ground is connected or not. Back in the old days....power supplies were real transformers....the effectively decoupled the DC side from the AC source. My old Kenwood has only a 2 prong cord....no earth ground. You can ground the case or not....makes no difference in sound.
