Can I ground a 2 wire circuit to a near by grounded metal box? The grounded circuit is 15 amp, the non grounded circuit is a 20amp.
If this is ok, am I correct in assuming that only outlets/boxes down stream from the ground will be grounded?
Basically I am putting a gfci and a couple of outlets into a bathroom on an existing 20amp circuit with more than enough capacity, but it is not grounded. I know the gfci will take care of this in a way, but I would feel better having the true ground in case of GFCI failure. However, there is a 15amp circuit which is real close by that I could pigtail a ground into where I am adding my outlets.
Thanks,
Thanks,
