bmxdad
Can a grounding rod, if needed, be installed inside a building?
My idea is to install it before the concrete is poured, under the sub-panel. Since there might need to be two at 6' apart?, the other would also be installed as the first, but farther down the wall. The grounding wire connecting them would be fed through 1" schedule 40 conduit, and then up into the sub-panel.
Thoughts ...
Thoughts ...
