Grounding wire multiple circuits.
PoorOwner
CA
One conduit going to another (big) box with 3 sets of current carrying wires.
Can I just run one ground wire then split the ground at the box instead of running 3 ground wires ?
How to size this ground wire ?
Actually, it’s emt so the box and conduit are grounded. I could have taken ground from the box without running ground wire. But just wanted to run one.
Firebrick43
West central Indiana
Size the wire for the largest circuit. For example if you have 2 15 amp conductors(14ga) and 1 20 amp (12ga) you would use a 12ga ground.
However you description rings some bells. This "big box" is not a sub panel is it?
Norcal
Pull a grounding conductor the same size as your largest conductor, no need to run 3.
teamextreme
Lakewood, CO
Only need one wire, sized to the size of the largest circuit. I would just use the EMT, but nothing wrong with pulling a separate grounding conductor.
P
PoorOwner
CA
Thanks. Big Box just helps me turn and branch off additional conduits.
Maybe 4 9/16 box
sberry
Brethren, Michigan
Use a deeper instead of a bigger box. I try to use as much common as I can, can keep extra in stock and have a future use for it.
alfredeneuman
Fullerton, CA
You only need 1 grounding conductor.
The largest size circuit will determine that.
15A a #14
20A a #12
30-60A a #10
60-100 a #8
If you have any conduits that comes out of the box, you can tap off a larger wire with smaller according to the the largest circuit in that particular conduit.
P
PoorOwner
CA
15A a #14
20A a #12
30-60A a #10
60-100 a #8
thanks, and I do mean 4-11/16 box... they have more space, but options for covers etc are limited
sberry
Brethren, Michigan
They are available, just not as common and I am in this class of use, never needed one in common garage work. Never. Got a whole box of various common 4 inch covers that can and will get used. I am sure someone has had a different experience and industrial is another matter but the most biggest stuff is 6 wire and not every wire in the place has to run down a single pipe.
sberry
Brethren, Michigan
Last welder recept I added or moved was a single circuit in about 4 ft of 1/2 pipe right to the panel, 3 number 10. I got 3 or so that way and a couple 6 in 3/4 , only a couple share a pipe. They are for 200 mig.
I have NEVER had or needed to come back and run a new welder wire down a pipe I had for a common outlet or switch loop.
