Not a lot of updates but some small progress none-the-less.
Last weekend was helping my dad drop and cut up a large gum about 2' thick at the bottom that was starting to rot up the inside and had dropped 3 large limbs in the last little while near where the kids play when they visit so it was a safety issue and had to go. Apart from that it was near to the house too and was able to be removed also under the bushfire regulations for the area.
While I was up there my Dad gave me a hand to do the timing belt, tensioner, water pump, belts, coolant etc in my Hilux (280000kms/174000 miles). They are changed around every 140000kms/87000 miles in my one. Worst part is the extra time it takes to pull enough of the dash apart to remove the gauge console so the timing belt light screw can be moved from one hole to the other beside it! At least I got to clean out the dead fly that's been in there for the last number of years bugging me.
Yesterday was a bit of tinkering in the garage so I got the bottom shelves cut and set into the mobile benches and I put down some of that conveyor matting I've been using on everything else on top. They are in their home now and have worked out well so far, but I haven't done any welding on them yet.
I was thinking about adding a drawer but then realized I need the top to be clear so that clamps etc can fit when clamping down projects. So will see how they go for a while.
During the week I need to visit a fastener supply place near work and see if they have any flush head bolts so that I can mount the vise upside down underneath when not in use as the big box store did not have anything like that. Also drilled bolt holes for the mini drill press to sit when needed. And it will be stored under the second bench when not in use.
View media item 57316
View media item 57317
The next small project between projects I think will be fixing up a small cupboard to be the trash and recycle bin.
View media item 57318
This is the current shop bin. 20Lt, 5 Gal bucket.
View media item 57320
The dustpan does have a home currently...
View media item 57321
I'll dig out some offcuts of ply and make up a slide out bin set, like you see in kitchens. The buckets are 10Lt, 2.5 Gal chlorine buckets that I picked up from my parents place. The buckets will sit high and the bottom has enough room to store other cleaning spray bottles and some rags etc.
The sliders came out of the camper trailer from a bodge slide out kitchen that the PO had put in that I removed.
View media item 57319
Thanks for reading. GB.
