Gun Cleaning Vise, Reloading Tool Bench Mounts
Bigblue&Goldie
It's been a while since I've actually made anything, but I (mostly) finished up a project I've had on the backburner for a while that some of the board's shooters might find interesting. Last year I started to streamline my reloading, which has resulted in me rearranging my reloading bench. Part of that is I wanted a way to mount some of my various tools to the bench in a secure fashion, but still have them quickly removed. I've decided to sink some 1/4"-20 anchors into my butcher block top and have my various tools mounted to 4"x6" plates with a corresponding hole pattern for socket head cap screws. I've yet to drill my bench for the anchors.....
First, here's the "universal" plate that everything starts with. I'm not sure what the material grade is, but they're .500" thick, 4"x6"ish bar stock. This one is actually a spare for a future tool, so it's blank other than the mounting holes. The holes are all drilled .281", then a counterbore was used, followed by a countersink to remove the sharp edge.
First tool I mounted was my old Forster case lathe. I used some SS button head 6-32 screws from another project that happened to be the perfect size. Simple drill and tap. There are 4 total screws, 2 on the backside out of view.
Next is the Primal Rights priming tool....an absolute work of art! The maker is a little kooky, but his products are beautiful. This one required (2) 3/8"-24 bolts. I only had some grade 8 hardware on hand, but I'll pick up some nice round head hex screws next time I'm at the hardware store.
Next up was something I've been wanting for a while. I have tried various methods for cleaning my rifles throughout the years. Everything from using their respective bipod, to a Tipton gun vise. Ultimately, nothing has been great. I designed this vise strictly for cleaning, with an additional purpose of mounting optics. The goal was to be able to stick a heavy *** target rifle barrel in the vise, crank it down, and be able to clean the rifle without having to hold it while working the cleaning rod ( :headscrat ).
The key elements were big ol' knobs to grab( :headscrat ), spring loaded top, soft rubber to protect the nicer gun barrels finishes.
The top plate was machined to allow for tilt caused by the barrel contour. 2 piece coned washers allow for bind free movement.
Here is an exploded breakdown of the parts. The base is the same "universal" plate as the other tool mounts. The padded jaws were made as separate pieces in case I wanted to make a different set down the road. The rubber is some outrageously expensive stuff that is chemical resistant and super sticky. The pads are 4"x4"X.500". It sits recessed into plates that are machined down .125" to locate it, and then clamped down on either side. Clamping hardware is SS 1" 10-32 bevel head screws leftover from another project that happened to work perfectly. The studs are 3/8"-16 on the base side and 3/8"-24 where the knobs thread on. The springs are flat ground so they sit nicely. All of the hardware came from McMaster Carr.
I would've liked to have had all of this stuff hard anodized, but the barstock was pretty rough. Instead, I'm sending it all to @CudaChick1968 to have her powdercoat it semi-gloss black. I'll post some follow up pics when I get it all coated and the bench top drilled......whenever that happens.
LXCam
Pretty nice Ryan. And very cool to send that all the way out to Leanna. Maybe have her do one of this super trick two tone numbers with your initials?
Monza Harry
Windsor ON
BB&G might I suggest a small radius or a medium sized chamfer on the mounting plate outer edges. I seem to be donating more blood to the "Project Gods" lately, an easy fix right now before Cuda Chick does her thing. Just looking out for your guns as blood stains don't wash off easily! Oh and your fingers too. :mad: Not bleeding right now but I'm not doing anything either, Harry
Bigblue&Goldie
Thanks Cam.... I didn't even think of anything but basic black.
I actually thought of that the whole time, but I don't have a chamfer or corner rounding mill. It's hard to tell in the pics, but I knocked the edges down with a file. Good rounding mills are expensive, but they're on my list of things to buy. Like they say, the machine is cheap compared to the tooling.
Firebrick43
West central Indiana
Very nice.
I did something similar several years ago. I had a base plate and multiple mount plates plasma cut. The baseplate was countersunk into the bench and hangs off the front. The mount plates have custom T bolts machined from standard hex bolts. They are inserted into the mount plates, adjusted for a tight fit when fitted to the base plate, and locktited in place. The mount plate with the shot shell press/o frame press press/barrel vise is dropped in to the base plate key holes and push backwards. The spring loaded pin at the front engages the hole in the mounting plate. To remove you just pull the pin down and pull the mount plate towards you and lift.
Sorry about the spilled Promo. Wife was reloading shotshells on the Ponsness and forgot a primer.
full
full
full
full
Firebrick43
I highly dislike rounding mills. If things in a manual mill are not set nearly perfect (or done in all one setup) they look like ****. Years ago I found some monster single cut files 2" wide and 12 inches long. I cut the tang and part of the tip off with an abrasive chop saw and safe edged them on a belt sander. It makes draw filing a chamfer quick and easy.
LXCam
Ryan if you want you can either borrow my 1/4 rounds or even do it at my shop later in the week.
I do a lot of edge finish work on the stuff I build. The only time my cut looks like **** is when I go the wrong direction.
Firebrick43
It has been long enough I don't rightly remember if inline was in business when I made mine? My dillon 650 is on a strongmount that is pretty much permnantly mounted to the other side of the bench.
EDIT (I looked it up and it was 2015 so inline was out at that point)
I really need to make some kind of rifle cleaning clamp. You have inspire me to add another project to me list! Thanks a LOT!
Who needs enemies when you have the Garage Journal dragging you under!
Firebrick43
So I went out and research your primer seater as I have never seen that model/brand and at 600 dollars it is not for me. But I saw they have a new vibra prime style tube primer filler, which I have been thinking about getting. What are you using big blue?
steaks&anvils
Colorado
Nice work! the mounts all look very well made and useful!
Your "barrel vise" looks a lot like the mechanism used on jewelers rolling mills to close the rollers. It closes both sides of the rollers, keeping them parallel, at the same time by turning the single middle handle.
If you decide that the two independent knobs used to tighten your vise are cumbersome to use (hold gun, tighten one side, tighten other side etc), maybe something based on the mill will work for you?
Google "jewelers rolling mill" (image view on) will get you lots of pictures.
FYI, there are cheap mills available for less than $100 that you might be able to appropriate parts from.
edit: I reread your text and now see that you allowed for play of the roundness of the barrel. Keeping everything parallel may not be helpful to you.
CudaChick1968
Member Emeritus
Northwest Tennessee (38230)
Wow, this one put a smile on my face today! It's an honor to even get mentioned alongside fine craftsmanship like yours Ryan -- having a hand in it will be a career highlight too! I look forward to working with you whenever you're ready (and don't feel obliged to use black, as there are literally thousands of choices). Straight up as always, the only tough part will be resisting the urge to use it on my own collection first before I send it back home :ROFLMAO:
