Gutter cleaning tool
DAustin
Has anyone used one of those gutter cleaning attachments that fit on a leaf blower? If so, did it work well or are they junk?
Yankee2bbq
Mountain Home, Arkansas
I have one on my leaf blower. They work…somewhat. You gotta make sure the leaves and gutter is dry. Also, if the gutter is to much packed with leaves…it doesn’t work good. Overall, I still use it.
AreBeeBee
Wisconsin
For what it's worth, the roof slope on our one-story house is shallow enough that I walk the roof with a leaf blower.
This time of year there are many leaves and other debris, so I use the corded (more powerful) blower. I also bring a set of long (24-inch) tongs with me to extract the more stubborn clogs. But from spring into early fall, I use just a 40v B+D cordless.
Besides clearing the leaves, it gives me an opportunity to inspect the roof for problems — damaged shingles, flashings, etc.
But clearly a steeper pitch or a two-story height would change the procedure!
iamhomeless
Indy
I have one for my sh86, it does work, the hardest part is actually controlling the whole thing, between force of the blower and the weight of the pipe running up in the sky, it can be a bear to hold onto. It does take multiple passes since some of the leaves you just blew out of one section will settle into the section you just cleaned.
It works better when the gutters are dry, but with a bigger blower, it can move wet leaves, but it will also blow the nasty water out and that will get on your windows, siding, and face, so it's better to so it dry.
captain14
I have the gutter attachment set up on corded leaf blower. As stated above, leaves have to be dry and don’t wait until the gutter is packed full. Sometime in the late summer, I’ll climb a ladder to make sure the gutters are clear of debris, then when the leaves start dropping, it’s every 5-7 days using the blower. It takes multiple passes to clear but once you get a system down, it’s easier. One story house on a basement.
Schurkey
I bought one of those extra-long compressed-air blow-guns. The sort with the four-foot nozzle. Then I put it into a tubing bender for a not-quite 180-degree bend close to the tip.
Plugged into 130 psi and two hundred feet of air hose, it works "ok" and I don't have to climb on the roof. It doesn't work any better than "ok", though.
Most of the time, I've still gotta climb on the roof and scoop the debris out by hand.
HPRifleman
Member Emeritus
Wayne, IL
I made my own out of PVC pipe.
It seems like a good idea but the biggest problem is that you still can't see if you got all the leaves out of the gutters. It blows air into the gutter, and leaves fly out, but you can only really verify if you get on a ladder and look. I have found that it's just as efficient to get up there and clean the leaves out by hand.
Skiff Builder
Southern NJ Coast
Clamp your wireless security camera on top of the elbow.
Mount a wireless camera looking over gutter as well as area of yard.
Mirror on a pole.
Visual inspection best if you can do it.
ATC
VA
Best thing we ever did was get gutter covers done by a local company. That said, I would have made something out of PVC if we hadn’t gone that direction. 2-story house
AreBeeBee
Wisconsin
Clever! Where does the Stihl blower stop and the PVC homebrew begin?
CJM8515
i have a ranch and the slope is not bad so i just walk up there and do it every few weeks. the trees like to dump the leaves right in since one of them is very close to the house. next year its getting gutter guards
HPRifleman
Member Emeritus
Wayne, IL
The black is Stihl. The white is me. 3" PVC reduced down to 2".
The 3" pipe just slides over the tapered Stihl nozzle and the weight holds it in place. Simply lifting on the PVC will remove it.
kaymccampbell
Upstate New York
I've got one from Stihl for my backpack blower. It works wonderfully. Dry leaves just flutter away at about 100mph. 4 inches of wet glop will blast out of there like an elephant with explosive diarrhea. I had to pressure wash the house, the walk and me.
AreBeeBee
Wisconsin
Ditto on the hard to control comment. I too walk along on the roof.
The very first time I used the blower on the gutter it was the corded one, and in a stroke of genius I decided the best approach was to remove & collect the leaves, vacuum-shredding them using the blower in vac mode.
But many leaves were wet, and of course the vac bag is somewhat porous cloth. So the vac sprayed me through the bag with filthy schmutz from the gutter: dirty leaf water, teeny bits of shredded leaves, plain ol' dirt, and (presumably) residue of raccoons using the roof as a toilet.
Now I do the inspection walk first to deal with any problems where a fast jet of air could be problematic. That vac bag has been permanently retired from the job — and I always note where the wind is coming from...
Earp69
I just got done installing this new gutter cleaning tool called gutter guards. Never clean another one again and it took about an hour to install on the whole house. It goes for as cheap as 89c a foot screws included. Wished I woulda done this from day one.
tester19
chigago
I have the really nice 4' long Al. section gutter guards by Leafproof. So many trees here and I spent a lot on clogged down spouts and cleaning drains as well. It's expensive as I paid $5200. For cleaning and install on a large single story house.
Leafproof
Citation
Indy
I do it with a DIY setup similar to HPR's. My ship vac can also be a leaf blower. Rather than directly attach the blower to my pvc, I use the original hose and leave the blower on the vacuum canister/base. The shop vac came with a nozzle that accelerates the air as it leaves. I attached that to the far end of my pvc works with some tape. I need to reach second floor gutters so my pvc section is quite long. I'm not sure I would want too attach the blower to the pvc directly even if I could.
ecotec
And this is the rub. It makes such a mess.
I had to clean mine, this year, while it was wet and nasty… like Kay’s… it stained my driveway. If you can do it while the leaves are dry… it is so much less messy. I used nitrile gloves, with work gloves over, for about half the house. It was a lot more work, but the lack of mess was worth it.
I always put it off until it is a gross job. I am my own worst enemy sometimes.
toplessHO
central florida
attach to the large wet vac
no mess to clean up
D
DAustin
Thanks to everyone for all the post. I went and got a gutter kit for my leaf blower and as soon as it dries out a little, I'll give it a try. It looks like the trick is to do it when leaves are dry. The kit didn't cost a whole lot, and if it works great if not, looks like I'll have to get gutter guards next year.
Stuart in MN
Minneapolis
Unless you clean the gutters frequently through the year, the leaves will get wet and dry over and over. They'll start to decompose and compress into a hard cake that you won't be able to get out by just blowing on it.
