Gutter & Downspout sizing
shooon
Dawson Creek, BC
Just had a contractor come install gutters and downspouts on the new shop. I was under the impression each gutter would have its own independent downspout, but it looks like he tied the two gutters into a common downspout and "T'd" into the one side.
We've had some crazy rain and flooding up here the past few years, within the 110mm + over a couple days type deal. Not sure what the max mm/hr or GPM equivalent was though.
It looks better ascetically the way he installed it... Just wondering if based on roof specs this is going to be adequate or if I need to split them into separate spouts as originally thought.
Roof area: 1100 sq.ft (550 per gutter)
Roof pitch: 4/12
Gutter length: 36' 5" K style per side (2x)
Downspout length side 1: 3x elbows 12' of corr. square pipe 3x4"
Downspout length side 2: 1x elbow 30' of corr. square pipe 3x4"
What do you guys think?
kbs2244
It isn't the length of the pipe, it is the size.
I would want 4x6, or even 6x8 pipes for that amount of roof.
And what about he gutters them selves?
Where they oversized?
To get an idea of what you need go behind a store in your area with the same sized roof.
You will see a professionally sized, and inspected, set up.
