GW 81204P 120XP Review
abvw
Toronto, Canada
So after 6 weeks of waiting, my 120XPs finally made it to the shop today!
First impression: something didn't feel quite right as soon as I picked up the ratchet from its foam tray. The balance was completely off, the ratchet felt much heavier than its predecessor (60T) that I've used daily for 6 months before I lost it. The head is noticeably thicker, and the handle feels a little smaller than it should.
That's about as much as I can provide today, I'll get back with more in-depth comparison tomorrow.
trout
Pennsylvania
isn't the 120xp just a 60t gear with 2 pawls? makes sense that it would be thicker and heavier to have the required strength.
TwoInch
NW INDIANA
since he does not have the 60t to compare it to, it might be a subconscious thing that makes it seem thicker.
i was under the impression they were all roughly the same, with the newer versions having rounded edges.
anyone confirm?
A
abvw
Toronto, Canada
anyone confirm?
I did have the 60T, I lost it 3 months ago and replaced it with 2 Dual80s, FHLF80 and FHL80.
I still have the nonflex 3/8" GW. I'll post some pictures tomorrow.
CWP1616L
USA
That goes to show you that there's no substitute for the real thing.
GearWrench = silicone breast implants :spit:
TwoInch
NW INDIANA
the 60t and 84t were pretty thin ratchets, as were the Cman thin profile which are the same.
im guessing the 120xp is in the area of a normal ratchet thickness then? isnt the dual 80 thicker than the matco.GW/armstrong ratchets?
Skin
Boston
Yes. The 1/4 Armstrong/Matco/GW are in a league of their own in terms of how "fat" they are. The 3/8" Armstrong/Matco/GW are the same thickness as a 1/4" T72. The 120XP is about as fat as a 80T 3/8" Snap-On. It is in no way unacceptably bulky unless the above mentioned thin ratchets are your only standard.
TwoInch
NW INDIANA
Left- Duralast, Middle-120 tooth, Right- 60 tooth
so, just barely thicker it seems.
still a damn thin ratchet if you ask me.
the soft handle does look a little skimpy though. probably figure that if you are needing a soft handle, you must have dainty hands....
evandonald
Ontario, Canada
I am interested in buying some gearwrench ratchets mostly because of the price. Would you guys recommend the 60 tooth over the xp series? Thanks!
03protege
Louisiana
I measured some of the ratchets I have, the 120xp is about a tenth of and inch thicker and wider than the 60t Craftsman TP. The head just feels really off balance.
I am not happy with the 120xp I have, although I am sure it will be a fine ratchet. I just don't think the added weight, thickness, and lower strength are necessary tradeoffs to see the swing reduced from 4.2 to 3 degrees.
